Results 1 to 8 of 8
Thread: Never Backwashing?
    Feb 2012
    Maryland
    400
    Never Backwashing?
    Ive read that you should backwash once your pressure rises 5 psi above normal.
    My pool was finished an opened the first of July. My pressure has not risen even 1 psi since them.
    Is it normal to not have to clean for over 2 months?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Never Backwashing?
    We recommend backwashing when your filter pressure raises 25% of your clean pressure.
    If your filter is fairly large a 1 psi increase would be normal.
    Do you use skimmer socks?
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Nice problem to have. Enjoy it!
    Mid Missouri
    227
    How is your flow and water quality?
    I put a Intex 2650 GPH sand filter on my 5500 gallon Intex pool approximately 2 months ago. Other than the initial setup; I've not had to backwash yet. The pressure has not risen the amount to require it yet and I have not noticed any significant change in the flow. Water quality is great, so it's doing it's job. I guess the infrequent backwashes are just a lucky bonus.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    22,553
    It's not uncommon for some people to go an entire season without backwashing. Some people only backwash upon closing.
    Aug 2010
    Dallas, TX
    4,052
    Welcome to my world!
    Ellington, CT
    263
    I started using the TFP method when I open my pool this past spring. After the initial pool opening clean up, I back washed my filter and have not needed to since. My pressure has only increase by ~1 psi over the entire season. When I was on the dark side, I would have to backwash at least twice a season based on a 10 psi raise in pressure.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Feb 2012
    Maryland
    400
    Glad to hear im not losing my mind. Ive been BBB since the getgo, but my "bleach" is a SWCG. Water is sparkling all the time!
