Results 1 to 7 of 7
Thread: New...quick test kit question!
    Hi everyone!
    I have been following here and there, and after many problems with my pool decided to go with the BBB method!
    So, first thing on the list was to get the test kit!
    I ordered the TF-50.....is that sufficient? I have put so much $$$ into this pool. I tried to go with the best economical version for now, since I will be closing it in about 3 weeks! I live in CT.
    21' round 52" high AG pool with a 19" sand filter 1hp pump
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    Re: New...quick test kit question!
    Your TF50 should get you through the rest of the year, depending on your water condition. I would suggest next year ordering a TF-100 refill (around $35). You will use up the reagents for CYA and FAS/DPD rather quickly. The refill will address that issue.
    Do you have a kit to test PH??
    Jul 2011
    Eastern Ohio
    7,099
    Ps.....where are my manners?? Welcome to the site!!!
    Thanks for the quick replay...and the welcome!
    I do have a test kit now which includes ph
    I'll give you a quick background.
    I opened our pool back in June, and had an awful mess! Lots of leaves/debris and dark green. I made the big mistake of heading to my local pool store and began the yo-yo of "add this" now "add this" and after a month had an "ok" looking pool.
    That is when I found this site and converted to bleach from the pucks. I still did not follow the method exactly though but looks got "better" and I mostly guesstimated (bad, I know).
    Per the pool store my CYA was 40, and I was testing FC and CC with a cheap kit. Adding bleach haphazardly...
    My problem is ALAGE keeps coming back, so now (a little late in the game) I realize I need to SLAM and use a reliable test kit.
    Current condition of the water is blue....very cloudy. This is after I brought a sample to the pool store and the said FC was 0.5. I added bleach yesterday and this morning just to keep the algae sort of at bay until the test kit arrives.
    When it comes I will return with test results
    Thanks again!!!
    Jul 2011
    Eastern Ohio
    7,099
    Sounds like you've got a hold of things, and are well on your way!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    You're headed in the right direction. Good for you!
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job ! We like to see good accurate test results.
    Jeff
