Thread: What happened to the forum today?
    Jun 2007
    SF Bay Area
    441
    I've tried to access TFP several times today, but with no joy. Finally was able to access and log on just a couple of minutes ago.
    What happened?
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Re: What happened to the forum today?
    looks like last post was about 10:50 am EDT, and yours is the first one since! Don't know, I could not access either... probably some leftovers from the BUU or something...
    I want my... I want my TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I emailed Sean to ask him and this was his response:
    I'm working with our server host, hostgator right now. They did not give me any advance notice, only an e-mail saying the site was exceeding alloted server capacities and that the site had already been disabled. I believe this to be in error and that they are probably including data from the upgrade, which is atypical usage. However, IF it is correct, I'll need to move to a dedicated server. Either way, the site WILL be back up, as soon as I can make it happen. I am unable to send out a mass e-mail without site access. If this is going to take a while, I may use the newsletter to send out a single e-mail.
    Please bare with me.
    Sean
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I went thru total withdrawls today....I emailed Sean just to get a fix....
    I check the forum every 30 minutes or so....
    Gosh, I guess I'm a TFP addict....
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Phew I thought I was the only one
