Thread: Running Valave actuator with a switch
    May 2013
    Dallas area
    85
    Hello - I have read here that you can run a valve actuator with a switch. I have found wiring diagrams in some of the owners manuals. It looks like you need a timer or a switch, 24 vac transformer and a single pole double action relay. If I am reading these diagrams correctly, the actuator always has power going to it and only stops because of internal limit switches. Is this correct? I am surprised if this is right because of possible switch failure and the transformer is always engergized.
    Am I missing something?
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Running Valave actuator with a switch
    Quote Originally Posted by aiannar974
    Actuators usually have a built in switch on the bottom and maybe that is what you were reading about. Actuators are normally run by a controller and the switch is used to change the direction of the actuator (on vs off) but you can also use it as a temporary bypass. You could probably build you own power supply and just use the built in switch but then why have the actuator? It is much easier to just move the valves by hand.
    Mark
    May 2013
    Dallas area
    85
    Only reason is to bring the control of the actuator over to the porch. This could be a switch, a timing switch or an insteon switch. I just cannot justify hundreds of dollars for a control when I have a pool with a light, a waterfall and no spa or heater.
