Results 1 to 8 of 8
Thread: Pool Heat Transfer Tools Spreadsheet
    mas985's Avatar
    Pleasanton, CA
    11,737
    I recently added the "Pool Heat Transfer Tools" spreadsheet to my list here if anyone is interested. I have been working on this one for some time and attempting to calibrate the results against my own pool. It gets pretty close to actual pool water temperature. Here is a list of features:
    • Heat Txfr - Estimates heat loss and gain from a full heat transfer model that includes the effects of the sun, solar panels, NG heater, heat pump, and environmental conditions. It downloads weather data from the internet based upon your location so an internet connection is required. It will also estimate the amount of water lost per day/week due to evaporation.
      Heaters - Compares operation costs of NG heaters and Heat pumps in a simpler format than above.
      Pipe Loss - Estimates the heat loss from a pipe with or without insulation.
      Pipe Freeze - Estimates how long it would take for a pipe to freeze.
    One of the biggest challenges was to get the Sky Temperature estimate correct for the radiative losses. There are many models for this but the one that seemed to work the best for my situation was to measure my own sky temperature and calculate the emissivity . Unfortunately, this may not work well for all locations which is why I would be interested in other's experiences.
    Most of the formulas used are from established sources such as: RSPEC
    Download Pool Heat Transfer Tools Here
    Keep in mind that this is still a work in progress and far from perfect but feedback and suggestions are always welcome.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool Heat Transfer Tools Spreadsheet
    I can download your other spreadsheets, but for this one I get the following error:
    403. Thatís an error.
    We're sorry, but you do not have access to this page. Thatís all we know.
    mas985's Avatar
    Pleasanton, CA
    11,737
    My mistake. Forgot to set the permission. Please try it again.
    Mark
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello Mark,
    Getting a Microsoft Visual Basic for Applications issue.
    Compile error in hidden module: TimeFunctions
    This error commonly occures when code is incompatible with the version, platform, or architecture of this application.
    compile error in hidden module: TimeFunctions
    mas985's Avatar
    Pleasanton, CA
    11,737
    Currently, the SS is Windows only. I am working on a version that will hopefully work on both.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    I get an error as well as I use a Mac:
    Run-time error '438':
    Object doesn't support this property or method
    As soon as you have a version that works on the Mac, I'll take a look.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Thanks to Richard, the spreadsheet now works for Macs too.
    Mark
    mas985's Avatar
    Pleasanton, CA
    11,737
    I found an issue with the weather update table query in the SS so if you were having trouble try this new version (same link): Download Pool Heat Transfer Tools Here
    Mark
