Results 1 to 20 of 20
Thread: How often should I shock?
    I am sure this answer exists on the boards, but I just can't find it.
    My pool is running steady chlorine levels around 3. I run a frog system to maintain the level. Do I still need to shock it, and how often?
    Thanks.
    Jake
    24' Round Vinyl-lined AG, 14K Gal., Hayward Xstream 1500 Cartridge filter w/ powerflow Matrix pump, Hayward H200 Heater, plus one ribbit
    Mar 2007
    Texas
    444
    Re: How often should I shock?
    Shock when you have a CC reading above .5
    27' Round AG, 17,200 gallons, sand filter
    Welcome Jake.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The Frog is making the rounds....
    ktdave's Avatar
    Katy, TX
    888
    Depends on what your water looks like and your combined chloramine (CC) level.
    Let us know what those are.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Hi jake0110,
    Lots of answers in "Pool School". Link located at the top of each page in the sub-heading and also in my sig.
    Welcome to the forum
    You're done SLAMing when:
    Thanks for the welcome guys. I checked out the pool school link, and I think I have my answer. Still, let me run my situation by you. Here is my info:
    I bought the pool last year, and the water quality has been great; clear, no odor. I check it frequently and I have a 150 gal saltwater fish tank, so I am used to balancing water chemistry. It is a 24' above ground pool, 14,000 gallons
    I use 4-way test strips. My current readings are:
    pH: 6.8 - i put in sodium bicarbonate this morning
    Free chlorine: between 1 and 3 ppm
    Total alkalinity: 120 ppm
    Stabilizer: near 0 ppm
    So..... should I shock every 10 days?
    Also, should I add chlorine stabilizer, even if the chlorine remains at a good level in the pool?
    Thanks again.....
    J
    Jake
    30,426
    Hi, Jake,
    Welcome to the forum!
    Uh-oh! Back to pool school
    Read up on stabilizer in "ABC's of pool water chemistry". (you need some) and "BBB for beginners" and "how to balance your pool water"
    Also "search" "test strips" on the forum and you'll see why few of us like them for anything.
    Use Borax to raise your pH.....baking soda raises your Alk....you're a little too high already
    11,969
    Sorry for my sarcastic comment before, I'm just not a fan of the Frog.
    Welcome to TFP. Before I answer your q's, I have a couple for you too!
    Is this a new pool?
    How are you testing your water? For example, are you using test Strips, is the pool store testing it?
    It's very unlikely that if your FC is running at 3, with tri-chlor, that your CYA is zero.
    I just want to clarify these two q's before we discuss shocking.
    Thanks!
    11,969
    Oh I see - test strips.
    Let me know about whether this is a new pool?
    ktdave's Avatar
    Katy, TX
    888
    Most importantly, I would suggest that you get a drop-based test kit such as the TF-100 sold by a TFP member duraleigh (http://www.tftestkits.com/) or the Taylor K-2006. The test strips are usually fairly inaccurate and hardly reliable for maintaining your pool chemistry.
    As far as shocking, in my opinion, it's not something done on a "schedule" but rather when necessary. For instance, I have yet to shock my 1 year old pool, just because my regular weekly (or daily) tests have indicated that I don't need to. You will be more closely in tune withyour pool chemistry if you have a drops-based test kit that includes:
    FAS/DPD test for chlorine
    pH test
    Total Alkalinity test
    CYA (stabilizer) test
    Calcium Hardness test
    yes, you need stabilizer.
    Pool School
    TF Test Kits
    11,969
    The instructions for the Frog tell you to shock 'every 2 weeks or more frequently' if hot weather and heavy bather load etc. There is a reason King tech tells you to do this.
    A properly balanced and maintained pool does not require routine shocking.
    Best advice I could give you is get the TF-100 test kit.
    Guest
    Quote Originally Posted by frustratedpoolmom
    It does if you want to try to maintain the pool with metals and .5 ppm FC!
    11,969
    Quote Originally Posted by waterbear
    EXACTLY!!!!
    OK. So I seem to have worked things out pretty well, thanks to your help.
    A couple of questions remain though:
    1. What is the difference between pH and alkalinity? The guy at the pool store offered an inadequate explanation.
    2. The pH increaser the store sells is Sodium Carbonate, but baking soda is Sodium BiCarbonate. What is the difference, and which one should I use?
    3. What's the deal with Borax? As above, the store sells Sodium Carbonate as pH increaser, but Borax is a different chemical.
    4. The store measured my Free Chlorine at 3.5, but Total Chlorine at 2.7. They do not measure Combined Chlorine. How can the TC be lower that the FC? How can I find out CC when the store cannot test for it?
    5. Finally, they suggested I use CYA to lower my Total Alkalinity. Is that the right answer?
    Thank you.
    Jake
    14,000 gal above ground pool
    I'll post other specs soon.....
    Jake
    1) pH is how acidic or basic the water is. This is the one you care about. TA is a measure of how much buffering there is in the water helping the pH stay stable. When TA is very low the pH can fluctuate wildly.
    2) Sodium carbonate is commonly called soda ash. It will raise pH quite a bit and TA some. Sodium Bicarbonate is commonly called baking soda. It will raise TA quite a bit and pH some.
    3) Borax, as in 20 Mule Team Borax, is a completely different chemical. It will raise PH quite a bit and TA just a little.
    4) The stores test results are just wrong. You should get your own high quality test kit and measure the levels yourself.
    5) No! Do not try to lower TA with CYA! There are instructions on lowering TA here.
    11,969
    OMG find another pool store. They are useless, clueless and will steer you wrong.....
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    There are three components to the chlorine content of a pool.
    There is FREE CHLORINE (FC) which is the chlorine available for use as a sanitizer
    There is COMBINED CHLORINE (CC) which is "used" chlorine, or chlorine which has combined with contaminants such as ammonia, sweat, etc.
    There is TOTAL CHLORINE (TC), which is simply the sum total of FC and CC.
    So if you know any two, you can determine the third.
    TC = FC + CC
    FC = TC - CC
    CC = TC - FC
    And I know it's been said, but you SERIOUSLY need to a) get your own test kit, and b) find another pool store. I mean, hey - I don't know the folks at your pool store, but they are certainly giving you bad advice. Real bad advice.
    I did try to buy a more comprehensive test kit, but they didn't sell any with CC, so I passed.
    I will go find a new store.
    Thanks
    Jake
  20. Back To Top    #20
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Quote Originally Posted by jake0110
    Thanks
    Even the big pool store chain near me does not have a decent (in my opinion) test kit for sale. I ordered mine (Taylor k-2006) online. Lots of members here use the TF-100 kit sold by duraleigh (a member here) and highly recommend both the kit, and the service that duraleigh provides. I know from ordering my Liquidator through him that he is very fast.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
