Thread: Pump rin time?
    Aug 2013
    Hilton Head, SC
    133
    Pump rin time?
    Looking at my pool info in my signature, can you suggest how many hours daily shoul I run my pump to get a complete turnover?
    Thank you
    Ed Marshall
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump rin time?
    Getting a complete turnover is not as important as running long enough to have clear water you are happy with. Often that is significantly less time then needed for a complete turnover. See: http://www.troublefreepool.com/pool-.../pump_run_time
