Results 1 to 8 of 8
Thread: Please I need help with heater hoses.
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    I have a Rheem pool heater hooked up to my 21 foot round pool. I am having an issue with the hoses the pool guy that installed the pool used. THey are grey somewhat heavy duty corregated hoses, but they are coming apart at the neck where they connect to the heater, I am assuming that its due to the hot water that is coming out of the heater. Does anyone have ideas on hosing that I can use to fix this with having to go to hard piping. I will convert to hard pipe if I need to but it is much easyer to use hose. I am having a hard time finding heat rated 2 in pool hosing. Any help will be welcomed!
    Retired Navy Chief (CTOC)
    21ft round 4ft AG 9367 gallons, floater with pucks as needed, Waterway PB 19inch Sand, Waterway PB 1hp SPL (not sure of type), Rheem LP Heater, Hayward Aqua bug, Aqua Luminator Light. Located in Iowa.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Please I need help with heater hoses.
    There is a flex PVC pipe available. However, it is intended to be glued into regular PVC pressure fittings. It will handle the heat, up to 180*
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    Do you have a link to where I can get this? Or can you tell me who supplies them. I have tryed all the Lowes and Home depots and they don't have anything that would work right. Thought about a hose like the ones you use in your radiator but cannot find that in 2 inch and 7 feet.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    How about short lengths of high temp silicon radiator hose, then a couple double hose barbs?
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    That might work. I was thinking radiator hose but was having a hard time finding the length needed. i assume most piping from heater to pools are rigid. Might have to just go that route, if this radiator hose or something similar does not work.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I ordered Little Giant 2" flex pvc from Amazon, and was with happy with the price and quality of the product. Nobody, not even the pool shops, stocked anything local to me.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    38,521
    I found 2" flex PVC at Ace Hardware ... HD and Lowes did not have any.
    BTW, are you using the Pool Frog and puck floater and UV system? None of those are really recommended by us, certainly the metal from the Frog is bad and you get plenty of UV from the sun.
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    Thanks! I just ordered some.
