Results 1 to 7 of 7
Thread: Question regarding PVC size when hard plumbing
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I have read about the use of 2' vs 2.5" PVC when hard plumbing pumps and filters. I don't understand how I get to choose. Wouldn't I need to use what ever size is dictated by the ports on the equipment?
    I know I used adapters on the SandPro to connect to the intex plunger valves. But we're only talking like a .25" difference.
    If the pump and filter have 1.5" ports, how would it benefit me to go to 2" or 2.5" piping. I'm picturing bottlenecking / higher pressure at one end and low pressure on the other.
    Kind of like a highway going from 2 lanes to 4 , pressure drops. Then abruptly returns to 2 lanes, pressure builds. Then finally releases into 4 lanes, lower pressure again, then thru the final 2 lane restrictive gate (this would be the return), higher pressure. Am I anywhere near correct? Is it that final push thru the return (causing better circulation) that we like?
    In layman's terms please. I'm no plumber.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Question regarding PVC size when hard plumbing
    Bottlenecking is not ideal, but keeping as much of the plumbing large will reduce a lot of the head loss in the pipes due to lower flow velocity. With that said, if you are not already planning on it, I would replace those intex plunger valves since they are very restrictive (and tend to break easily).
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Already bypassed one plunger valve when I installed the skimmer. I have the return eye that came with the skimmer and plan to replace the return plunger with it.
    So, should I go as large as 2.5" ? Or stick with 2". Keeping in mind that if I come across a 3/4 hp 2 SP pump I'm going to trade out the 1.5 hp. If this matters.
    Angie M.
    As water flows through the pipe it constantly loses pressure. If there is a bottle neck in the line the pressure drops more through the bottle neck but does not gain any pressure after passing through the bottle neck. The difference between 2" and 2.5" will be minimal due to short length of pipe and low flows.
    15x30 above ground pool
    Hayward S180T Sand Filter with 1.5 hp pump
    Central Kentucky
    38,251
    2" is more than adequate. No real reason to go to 2.5" unless you have a very big pump ... plus it is harder to find 2.5" pipe and fittings.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank y'all for the info. Looks like it'll be 2" then. Cool. Can't wait to get started. Thunderstorm right now.
    Angie M.
    Jul 2011
    Bedford, NH
    67
    Taterfink...post pics! I'm closing my pool today, but pouring a small concrete pad and might dry-fit the PVC in the next week to be ready for next year.
    18' round above ground, vinyl liner, 48" deep (flat), Confer Step1 steps. Approximately 7600 gallons. Waterways/Proline FC075 cartridge filter. 75GPM (71 minute complete cycle), 75 sq ft filtration area.
