Results 1 to 13 of 13
Thread: CYA and PH Reading
    Wildcat's Avatar
    Jun 2013
    309
    CYA and PH Reading
    The forum as told me that with high CYA PH can read higher then it really is.Is there a correction factor that will allow me to gauge my true PH? I am working on my CYA but it is 125-130 and my PH measures at 7.5. What is it really?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Re: CYA and PH Reading
    High CYA will not affect your pH reading.
    High FC, above 10 ppm, will.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    There is no "correction factor", sorry. If you want an accurate PH reading you'll have to let your chlorine level drop below 10. Thats assuming its above 10 now. If its not its too low for your CYA level and you're risking an algae outbreak.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Wildcat
    This forum told you high CYA will skew your pH? I must misunderstand you.
    Maybe you have this mixed up with high FC on the color block test.
    Essential Links:
    Wildcat's Avatar
    Jun 2013
    309
    Sorry, I did mean FC. High CYA causes me to keep high FC thus skewing the PH results. My FC is in the 15-18 range with CYA about 125 so I have the Algae angle covered.
    Wildcat's Avatar
    Jun 2013
    309
    ph-at-high-fc-levels-t11428.html
    I should have done a search before asking my question. I actually understand most of the answer. But where is a chlorphenol color chart to be found? It seems to say that allows a reading even at high FC
    I have found that the pH reads accurately when the fc is below 15 percent of CYA and is read right away.
    What are your current pH and TA readings?
    Support the site
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by JamesW
    7.4 and 100
    http://www.troublefreepool.com/ph-at-high-fc-levels-t11428.html
    For an FC below 20, using Taylor chemicals, you won't get an accurate reading by looking at a chlorphenol color chart. The thread you referenced from The Deep End explains this. All of the recommended test kits - Taylor's, Leslie's, and the TF-100 - use Taylor chemicals.
    The standard recommendation here is to lower CYA, for this reason as well as others.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Most likely the pH reading is correct. For your cya, you can maintain an fc of 9.5, which will help you obtain a more reliable ph reading.
    Support the site
    Wildcat's Avatar
    Jun 2013
    309
    I guess I thought it was best to maintain my target level than the minimum. I think target level fo rmy CYA of around 125 is 16. Maybe I'll let it drop to the minimum in order to check the PH and then bring it up some to be safe.
    Just my luck as i am trying to count on rain water to help my refill we have had lower than average rain this monsoon season. Less than 4 inches and we had around 10 last year.
    For your CYA, I would keep the FC in the 10 to 20 range, but as close to 10 ppm as possible without going under. A lot depends on how frequently you test and add more chlorine. 15 to 18 ppm is fine is that's what it takes to ensure that you never go below 10 ppm.
    Ideally, it would be best to get the CYA down to a better level.
    I think that your pH readings are probably accurate as long as you are mixing the sample and matching the color right away.
    The risk is that if the pH is reading a false high due to high chlorine, then the pH might be too low. However, based on the TA, I don't think that it is.
    Support the site
    Wildcat's Avatar
    Jun 2013
    309
    Yes, that is what I inferred also, that with my TA PH is probably about right.
    Another 100 degree day in Tucson. Looks like it could be a long pool season
