Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Not quite sure..
    Aug 2013
    Nashville, TN
    30
    Not quite sure..
    Pool.............. Fill
    37.........FC.....3.25
    1...........CC......0.50
    7.2........PH........7.4
    110.......TA.......130
    160.......CH.......140
    85........CYA........0
    1600....Salt.........0
    26.....Borates......0
    0.0....Copper......0.0
    1470....TDS......195
    6...........PSI
    Pool water looks clear. I have been SLAMing for over a week now. And I cannot pass the overnight test or rid my pool of the CC.
    As of tonight I am losing 1ppm per 90 minutes and have an average change from 38 to 15 in 11 hours
    The water looked clear when I started this process (there is old Carpeting placed upside down under my liner and I could see the design of the carpet) and was wondering if anyone has an idea why this is taking so long. I have gone through over 45 (121oz) jugs of 8.25% bleach. I have been checking the chlorine level constantly. And have never let it fall below 12 FC.
    I do know that some of my tests aren't needed but I was curious and figured I'd post all my results.
    10k AGP 19" sand filter 1hp pump
    Aug 2013
    Nashville, TN
    30
    Re: Not quite sure..
    Oh yea, I have been back washing my filter every other day during this process. It does spew out some white cloudy water but I only need to flush for 30 seconds before it's clear again.
    I have also for the last 2 days been slowly dripping diluted bleach in front of the return jet in hopes of keeping my chlorine up in the mid 30's
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I know its an AG put do you have a light or ladder where algae could be hiding ? Have you been brushing ?
    Jeff
    Well, there's something organic in there somewhere. It's time for a good game of hide-and-seek. Popular places for algae to hide out include light niches (if you've got them), under the ladder, in the ladder if there are holes to sneak into. Try taking as many items as you can out of the pool and give the pool surfaces a good brushing everywhere. If you have lights--flip the breaker and remove them from the niche.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Aug 2013
    Nashville, TN
    30
    I do not have any lights and I will pull my ladder out in the morning and will leave out for a few days to see if that helps.
    Steps
    Steps during day
    Pool at night
    Pool during the day
    Aug 2013
    Nashville, TN
    30
    I have been brushing just about every day and vacuum just as much. You can't really tell but the ladder floats a few inches off the bottom so its easy to vacuum under and behind it.
    I just removed the steps so we will see how it goes tomorrow.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Try the ladder and see what happens. Have you been brushing ? How about the pool vac and hose ?
    Jeff
    Are you covering it at night? If so, has the cover been on for any of the SLAM? It might be housing some organics.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ok I see that you have been brushing.
    Jeff
    Aug 2013
    Nashville, TN
    30
    The cover has been off during the process until last night. I will remove it again in the morning and it will be off for most of the week.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What was the reason for SLAMing ? In your first post you stated the water was clear to start the process.
    Jeff
    Aug 2013
    Nashville, TN
    30
    To try and rid my pool of the 1.0 CC.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    May I ask what test kit you are using ?
    Jeff
    Aug 2013
    Nashville, TN
    30
    Taylor K-1766 Salt test
    Taylor K-1730 Free Copper test
    LaMotte instant test borate strips
    TF-100 with speed stir
    And my DM1 Dual TDS meter.
    Aug 2013
    Nashville, TN
    30
    Well.
    At 7:48 pm last night, I had 37 FC.
    At 10:00pm I removed the ladder.
    I slowly dripped 121oz of 8.25% bleach (8ppm FC)
    Ended this morning at 8:42am with 31.5 FC, tested just after I removed the cover.
    Soooo......
    Last night with nothing in the pool I lost 13.5 FC.
    Going to add half a jug of bleach and set up the drip, for the day.
    30,432
    I see nothing in your test results or your procedures that would account for your FC loss.
    Rather than go back and hash out what might have caused this, let's work on the cure.
    As you know, chlorine in your pool is consumed by only two things....sunlight and organics in your water.
    From your last post, you have indicated a 13.5 FC loss and have eliminated sunlight as a factor so the inescapable conclusion is you still have organics in the pool.
    There is really only one solution...keep SLAMming.
    I would continue to maintain the FC up around 30 ppm (roughly) and only take accurate FC measurements in the evening and in the morning.....keeping the sunlight factor out of the equation and allowing you to judge your overnight loss each 24 hour period.
    You should see a steady decline in FC loss. There really is no other realistic result.
    Keep us posted.
    Aug 2013
    Nashville, TN
    30
    I hope I see something soon. I bought 8 jugs of bleach for $26.16 yesterday and that will be gone by noon. I only have one left
    I have spent over $200 on supplies to SLAM a clean pool just to get rid of the 1.0 CC reading.
    I guess I just thought that if the pool was clean, sparkling, and not at all slimy, I could get away with only needing 6 or so jugs. Guess it doesnt work like that. Going at this rate I'm going to come out ahead if I just drain and refill.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Target stores in a lot of areas have their brand (up and up) bleach on sale buy 3 get 1 free. 8.25% 121 oz. Under $10 for 4 jugs... if they have the sale in your area you could save a little $ that way. Not a solution I know, but it might help a little.
    Hope you get to stop SLAMming soon!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    30,432
    Conflicting info here....were you trying to get rid of 1 CC or were you also failing the OCLT?
  20. Back To Top    #20
    Aug 2013
    Nashville, TN
    30
    I started the process to remove the CC in my pool.
    To SLAM you must pass the tests.
    No CC
    No chlorine loss overnight
    A clear pool.
    I said "ok, I have clear water now let's try the overnight test. I failed that. I have also failed the third requirement. I have more than 0 combined chlorine.
    Now I am trying to get rid of the CC in the pool and pass the overnight test.
    How is this conflicting information?
