Results 1 to 8 of 8
Thread: Liquidator for AGP dose it work good?
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I've been considering putting one in but I'm not sure how well they work on an above ground pool. Any info from people that have them would be helpful.
    Thanks
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    Mar 2007
    Texas
    444
    Re: Liquidator for AGP dose it work good?
    I have asked this same question a couple times on here and have seen other post asking this as well, all with no answers. So either no one is using the LQ with ABG or for some reason no one will answer this question I will keep an eye on this post to see if you do any better then I did
    27' Round AG, 17,200 gallons, sand filter
    Guest
    There is no reason it would not work as well on an AGP as an IGP BUT, if I am not mistaken, you need to be plumbed with hard PVC to connect it. It's not really that big a job to replumb with hard PVC if you are using flex tubing but it is an additional step.
    Oct 2007
    Va Beach, VA
    41
    I have asked this question before as well. See this thread for answer:
    liquidator-and-agp-t6154.html
    BBBB?-Bleach, Baking Soda, Borax, BEER!
    18' x 33' x 54" AG Pool, Vinyl Liner
    17,700 Gal
    Pump: Baquapure Workhorse Superflow, 2.5HP, 2 Spd
    Filter: Baquapure High Rate Sand Filter, 26 inch
    Baquapure Water Polishing System
    Proud new Papa of a Pool Rover Junior! Born 6/20/08
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Quote Originally Posted by waterbear
    Mine is all hard piped so that's not an issue
    I thought I read some posts were the Liquidator should be above the water level in the pool! I don't see it in the instructions about having to do this but thought someone in here was having problems with there's because of that. I can't find the post now, but I don't see why it wouldn't work your dealing with pressure on one side of the Liquidator and a vacuum on the other side so regardless of the water level it should work. correct? or am I mistaken
    Quote Originally Posted by Tdog
    Thanks! When I did a search that thread didn't come up (or I missed it). I think after reading that Ive made up my mind!!
    Hayward 40 GPM pump
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    So are there may AGP owners using the Liquidator or not?
    Hayward 40 GPM pump
    Mar 2007
    Virginia Beach
    272
    There are two potential problems that you may run into on an AGP:
    A. If you have a very short pipe ruin from your skimmer to you pump, you might not be able to build up enough suction to pull adequate amounts of CL water back into your pool. This can be corrected by either increasing the length of the run or more easily by restricting the flow into the skimmer with a valve.
    B. The check valves on the LQ will sometimes restrict the flow somewhat to where it is not high enough to sanitize. An easy fix for most owners is too remove them as they are not normally necessary. However if your LQ is installed below pol water level (as on most AGP's), then they are necessary. If you cannot get enough flow you can raise the LQ above water level and remove the valves.
    Both are fixable and IMO shouldn't deter you.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Jul 2007
    Northern NJ
    299
    I reposted the pictures in the above thread. Something changed during the upgrade and pictures are no longer viewable. I will post a picture of my actual set up later today or tomorrow.
    One problem is getting the flow up high enough. I can only get mine up to about 3.5 and that is with the skimmer valve partially closed to provide some additional restriction. I also switched from 6% to 12.5%. My FC runs around 4. I intend to do some additional tinkering to see if I can get a better flow, but I just haven't had the time.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
