Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Pump won't turn on - Jandy Stealth
    I went out yesterday to a dead calm pool.
    My pump & cleaner were ON but no water was moving. So I checked and sure enough all was quiet. My pump just isn't running at all. No noises etc. When I try to turn it on at the panel I just hear a click in the panel, no noise at all from the motor/pump.
    Is there something I should check before calling a repairman? There are no breakers tripped and I have power to the panel. That's about as far as I got.
    Thanks
    25,000 gal plaster IG
    DE Filter
    Jandy SWG, 2.0hp Jandy Stealth pump
    DFW Area
    22,542
    Re: Pump won't turn on - Jandy Stealth
    Is the pump on a timer? If it is I'd check to make sure it's working.
    Does it make any noise when it tries to start?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Bama can help you
    I had this same problem last summer. help-pump-wont-come-on-suspect-electrical-problem-t52254.html
    My timer had been fried by lightning and I was able to figure it out and bypass timer. I didn't replace the timer until this summer......and those pics I took saved me. I'm no electrician and didn't remember what I'd done to bypass it a year later. The pics pretty much walked me through my timer reinstall this summer.
    Check electricity voltage starting at the pump and work your way back.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    It's not the timer I don't think. I can put the panel in service mode to manually fire the pump and it still doesn't work.
    I can post pics tomorrow of my setup.
    Thanks
    DE Filter
    DFW Area
    Smykowski's Avatar
    Sep 2011
    3,065
    But if the timer is bad, the manual mode won't work either. I'd break out the multimeter and rule out the timer.
    22,542
    It sounds like you don't have a timer as such. Is it an automation system?
    Let me take some pictures and post. I'm honestly not sure what I have. I do my schedule and operations from the Jandy remote.
    DE Filter
    DFW Area
    Here are pics of what I have
    DE Filter
    DFW Area
    22,542
    If you try to manually start the pump, can you hear the relay actuate?
    all I hear is an audible "click"
    DE Filter
    DFW Area
    Anything else I should consider before calling a repair company?
    DE Filter
    DFW Area
    would you guys advise me to purchase this?
    http://dallas.craigslist.org/ndf/for/4018753575.html
    DE Filter
    DFW Area
    22,542
    If you hear the relay clicking then either there's a problem with the pump or you're not getting power to the pump. Are you comfortable testing for voltage at the pump?
    Sep 2015
    Frisco, TX
    1
    Quote Originally Posted by Texonfire View Post
    What ended up being the issue on this? I am having the exact issue and I have the exact equipment. Thanks!
    Same issue as well.
    Automation systems make a click when the relay actuates, but no noise or action at the pump.
    I tried swapping out the capacitor, but nothing changed.
    I opened up the Hayward Aqua Logic system, nothing looks blown out.
    Update:
    I tested w/ the multimeter, this was a big help: How To Use a Multimeter to Test a Pool Pump Motor - Voltage - INYOPools.com
    power was getting to the pump. I cycled it on/off a few more times then heard a pop and saw smoke coming from the motor.
    Not what I was hoping for!
    Oct 2015
    watuaga
    8
    The clicking doesnt mean the power is getting to the pump, use your multimeter or a touch voltage indicator to see if there is current to the motor. If there is power to the motor your doa at this point.
    I am having the same issue....guessing the pump is toast?
    What did you guys end up finding?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    Mar 2015
    New Orleans, LA
    81
    This is usually an indication the the breaker in the panel is tripped. Even though it doesn't look tripped go back and forth a few times. The jandy system will show it on but that doesn't mean power is getting to pump.
    Quote Originally Posted by ConradM View Post
    Well my waterfall pump is working along with all the other Jandy functions..the unit has power it just clicks when trying to cycle the pump on..Maybe the pump is what is clicking but something is trying to come on..I think my motor might be fried?
  20. Back To Top    #20
    Mar 2015
    New Orleans, LA
    81
    Is the waterfall pump on the same breaker. Usually not.
