Thread: Acronyms
    Aug 2013
    Ben Lomond, CA
    17
    Acronyms
    Greetings,
    I have figured out most of the acronyms used here, but what do these mean:
    1. FAS-DPD
    2. In the TF-100 kit, what does TF stand for?
    3. OTO chlorine test.
    Swami
    I am a student at the Pool School. 28K gal IG plaster, Filter: sand Tahitian model HR25 size 3.4 sqft flow rate 68 gpm, motor 1.5 HP, Polaris, Pool built in 1973. Pool gets about 10 hours of sun daily, I use TF100.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Acronyms
    1. Ferric Ammonium Sulfate- Cant remember the chems for DPD
    2. Trouble Free
    3. Cant remember the chems in OTO either, but also a chemical. None of these are actually acronyms.
    Essential Links:
    22,544
    Re: Acronyms
    There are two different chlorine tests that use the DPD reagent one that's just DPD and the other that allows you to test high FC levels uses the FAS reagent with the DPD reagent.
    As Patrick said it's Trouble Free.
    OTO is orthotidine it's used to test total chlorine.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Acronyms
    The chemical names in the test kits are listed in this post. You normally do not need to know this information.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Acronyms
    I knew that chem geek would be around to answer soon enough. He never disappoints.
    Essential Links:
    Aug 2013
    Ben Lomond, CA
    17
    Re: Acronyms
    Thank you all.
    Best wishes,
    Swami
