Thread: Hayward SP1082k4 Weir (Broken Tab)
    On my 2nd season with my pool Had some family over yesterday. Two 10 year olds where doing canon balls in the deep end. Shortly thereafter I saw the skimmer weir door floating on the water, tab missing and at the bottom of the pool. Are these that sensitive that 75lb kids jumping in the water can slap a weir hard enough to break?
    So is this repairable or needs replaced? OEM or third party? Amazon has this:
    http://www.amazon.com/Hayward-SPX1082K- ... p1082+weir
    So fix, stay Hayward or third party?
    Thanks and have a great Labor Day !!
    Ted
    Nelsonta43's Avatar
    Sep 2013
    South Mississippi
    7
    Re: Hayward SP1082k4 Weir (Broken Tab)
    I have the same problem. The tabs on the OEM look a little flimsy. There are some third party ones that once they are put into place a pin is pulled to release a spring loaded hinge pin. I ordered the OEM, now im having second thoughts.
    Thomas
    "The best thing you can add to your pool is swimmers"
    22,000 Gal 16x32 Vinyl Inground, Hayward S244T filter, Pentair Superflo 1HP, Polaris 165
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    We had the same problem this weekend when there were about 20 teenagers over. Did your replacement work OK or would you recommend something different?
    18 x 36 vinyl liner IG pool, grecian shape, ~27k gal
    1.5 hp Hayward Super Pump, Hayward DE3620 Filter
    Hayward Aqua Rite Electronic SWG, Dolphin Triton PS robot
    TF-100 test kit with SpeedStir
