Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Milky cloud
    Milky cloud
    Topics merged. Please don't multiple post duplicate posts. Bama.
    52"
    13,000 gallon
    Had an algae outbreak. Killed the green algae. Pool has now been milky cloudy for 2 weeks.
    Have read pool school. Added tons of shock. Added clarifier. Been vacuuming regularly. Nothing is working. Thinking about blowing the pool up. Any help would be appreciated.
    FC: 15
    ALK: 180(high, but it has been lower until recently)
    pH: 7.8
    the: 450
    * 24' x 52" Above Ground pool - Installed in May'13
    * 13,000 gallons - Filled with City water
    * Aqua Pro 1.5 HP - Pleatco Cartridge Filter
    * TF-100 Testing Kit
    Milky cloud
    52"
    13,000 gallon
    FC: 15
    pH: 7.8
    the: 450
    Re: Milky cloud
    Sorry about that. I didn't think the posts were going through.
    22,544
    Re: Milky cloud
    Welcome to TFP.
    How did you get those results?
    You need a good test kit if you don't already have one.
    You also need to read the ABC's of pool chemistry.
    Follow the advice you find here and you'll be clear soon.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Milky cloud
    Welcome to the forum
    Here's a list of things we'd like to know to be able to help you best: pool-school/read_before_you_post
    A pic of the pool would also help
    You're done SLAMing when:
    Re: Milky cloud
    Quote Originally Posted by Butterfly
    13,000 gallons
    AG pool
    Cartridge filter, 2hp pump
    Installed in May of this year(2013)
    Here are the strips I used to get the chem results. I also took a water sample to the pool place and the numbers were about the same.
    Here is a few shots of the pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Milky cloud
    One thing that would help you out is getting a good test kit. The TF 100 is the one I use. You can get one at TFtestkits.net. I would also get the XL option. The test strips just aren't up to the job of pool water maintaince.
    The pool store isn't much good at it either.
    Take a look at this pool-school/shocking_your_pool.
    Welcome to TFP !!
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Milky cloud
    Quote Originally Posted by sm1zzle
    What exactly do you mean by this statement?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Milky cloud
    Are you cleaning the filters every so often unti it clears?
    Re: Milky cloud
    Quote Originally Posted by Smykowski
    I've been adding a bag or two of shock every night for like a week and a half
    Re: Milky cloud
    Quote Originally Posted by woodyp
    Every couple of days I take the filter out and clean it. The water does not appear to be getting any clearer though. When I vac I see the white particles coming back into the water from the return.
    Pump had been running 24/7 also.
    22,544
    Re: Milky cloud
    Can you tell us what the ingredients of the "shock" is?
    Re: Milky cloud
    The one I had been using, Shock X-tra from Menards, has sodium dichlo,alkyl and 35% available chlorine.
    What I have now is the Walmart Super Select shock by hth. It has Calcium Hypochlorite @ 56.44%.
    I've been using this for a few days because I've wiped out the Shock X-tra at Menards.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Milky cloud
    Do you know your CYA level?
    We recommend a good test kit and without full results from a good test kit it is hard to know where to start or what is going on with your water.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Milky cloud
    I'm not sure but the mixing of the two and anything else you added might be contributing to the cloudiness.
    If you would consider getting a good test kit and do some reading in pool school we can help fix this for you.
    Jeff
    Re: Milky cloud
    Quote Originally Posted by pwrstrk
    I was using the first brand of shock for over a week and the water was the same then as it is now with the brand I'm currently using.
    I will buy that test kit for sure but probably not within the next week or so.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Milky cloud
    There is a link to a good source for a test kit in my signature. Honestly it sounds like you are throwing things at the problem without understanding of what you are adding to your water. These "Shock" products add additional chemicals to the mix. If you invest in the test kit and invest your time in understanding the ABC's of pool water chemistry the savings to your wallet will exceed the cost of the kit.
    To clear your water you need to SLAM your pool and in order to do so you need to know your CYA level because chlorine levels required to sanitize and or kill algae are dependent on your cya level. You also need to be able to accurately measure your chlorine level higher than 10 and for this you need the FAS DP test kit.
    22,544
    Re: Milky cloud
    Without a good test kit and good results, it's hard for us to guess what is causing the problem. Take a sample to a local pool store and post them here when you get them.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Milky cloud
    Quote Originally Posted by AimeeH
    Very well said.
  20. Back To Top    #20
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Milky cloud
    Very well said.
    Thanks. I've learned just about everything I know about pool care from hours and hours on this site. Discovered it when my pool was about a month old. I didn't invest in the kit until opening in the second season and now I don't hesitate on the cost of refills etc. I've never been "pool stored" and maintenance is a breeze. Best investment for SAVING money there is.
