Thread: PH Keeps Increasing
    May 2013
    Manchester NH
    16
    PH Keeps Increasing
    Split from ph-keeps-increasing-t66544.html Please start your own thread when asking a question, rather than hijacking Thanks, Butterfly
    i am having the same issue. same test kit. new pool (water added july 2013). started on trichlor, switched to bleach when i found this site, CYA was 80 now it's 45.
    here are all the numbers from tonights test:
    FC 7.0
    CC 0.0
    pH 8.0
    TA 100
    CH 110
    CYA 45
    is it normal to have to add acid once a week even when the TA comes down? is this where borax might help?
    thanks admitted pool novice here.
    28000 gal inground vinyl installed 7/2013, hayward c5030 525 SF cartridge filter, hayward SP3400VSP variable speed pump, hayward 125000 BTU heat pump, chlorine dispenser
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: PH Keeps Increasing
    Lower your PH with acid and your TA should come down a little also. If PH drifts up to the high end again repeat. Your PH might like a little lower TA.
    You just made a switch to bleach. It may take sometime for everything to settle in.
    The borax won't help you, it raises PH.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by planker88
    FC 7.0
    CC 0.0
    pH 8.0
    TA 100
    CH 110
    CYA 45
    Only once a week? You're lucky!
    Every pool has its own personality, and yours just isn't one of those set-it-and-forget-it ones. As you keep adding acid to control pH, the TA will slowly drop and the time interval between acid additions should increase.
    30,431
    +1 what Richard320 said.
    Forget borax for now....not applicable until your pool "settles in"....maybe in a couple of weeks.
