Thread: EcoStar VSP & DE 3620 Getting DE in the pool at low rpm
    Jul 2013
    Puerto Rico
    76
    Hi!
    I set my VSP to run at 1000rpm and am now getting DE in the pool. Once the pump runs at higher rpm over 2000rpm, there is mo problem.
    Any hints?
    Thanks!
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    22,550
    Re: EcoStar VSP & DE 3620 Getting DE in the pool at low rpm
    It shouldn't make any difference what the pressure and flow is, nothing should bypass the filter. I suspect that there's a seal or hole that's closing under higher pressure. Take the filter apart and inspect it really well.
    Jul 2013
    Puerto Rico
    76
    Thanks!
    Will do so & post findings!
