Thread: Polaris 360 - can I use the hose like a Polaris 280 does?
    sammm's Avatar
    North Richland Hills, TX
    257
    Hi all...I have a Polaris 360 cleaner that uses the large diameter corrugated plastic hose, and it seems like it is always springing little pin-hole leaks. We were at a friends today that just had a new pool installed. They have a Polaris 280 cleaner that uses a smaller and heavier hose. Looks like heavy rubber tubing instead of cheap plastic.
    Can I retro-fit my 360 to use that same hose?
    Here's what my 360 hose looks like:
    http://www.ebay.com/itm/Polaris-Feed-Ho ... 4d101001a2
    Here's what the 280 hose looks like:
    http://www.ebay.com/itm/111157059418?ss ... 1438.l2649
    Thanks in advance!
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    22,553
    Re: Polaris 360 - can I use the hose like a Polaris 280 does
    While they're both pressure side cleaners, you most likely won't get enough flow through the smaller hose to run the 360. The 280 runs at a much higher pressure and lower flow than 360 does.
    sammm's Avatar
    257
    Bummer...thanks for the reply Dave!
