Results 1 to 11 of 11
Thread: Pool sweep suggestion
    I am having a new pool installed (roughly 35x9' rectangle, with a "shamo" shelf attached at one end/side, 12,000 gal). I have 6 returns specified (3 near bottom of pool to pipe heated water to bottom, 1 at each end to create a circulation, and 1 90 degree pointed at my "shamo shelf"; I'll have one skimmer). I live in CA, so I have to program my pump to not go over 36 gpm. All lines will be 2", the filter will be a 320 sq ft Pentair. There will be tree leaves in the pool at certain times of the year (a tree is near the pool).
    The pool builder is recommending adding a (separate) return for a Polaris 360 sweep, as that model wouldn't require a booster pump. We need to decide to do this or use a robotic cleaner. Would a Polaris work? My current electrical rates are 31 cents/Kwh, so I want the option that uses the least amount of electrical power. Note that no plumbing has been done, so "anything" is possible at this point.
    mark
    ~12000 gallon gunite pool, Pentair Intelliflo VS, Pentair 320 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch, NATURE2 PROFESSIONAL "G", Pentair 320 auto clorinator, UV
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool sweep suggestion
    Welcome to the Forum!
    A pressure side cleaner with a booster pump to run will be handy with leaf debris. I will have a lot myself and I am going with one for sure.
    Essential Links:
    30,421
    Most pool cleaners work to some degree or another. I have heard good things on the forum about the 360 but have no personal experience.
    For your size pool (you pay for cleaning power) a 360 would be about the right size. I personally prefer a robot over a pressure side cleaner if you decide to spend the extra money over the 360.
    It boils down to some personal choices that will require some reading and learning.
    Quote Originally Posted by Brushpup
    The question is, then, which draws more power: a booster pump or a robot. I see that a "Dolphin Premier" robot draws 180W and recommends 2.5 hours (so 450W per day). I can't seem to find an equivalent data sheet for booster pumps.
    22,550
    Booster pumps are 3/4 hp so they draw about 1500 watts.
    So for a new pool (where I have a choice of what to start with), a pool sweep that requires a booster bump would use significantly more energy than a robot (which draws 180W).
    30,421
    Correct.
    30,421
    However, you then have to calculate how much "work" a 180 watt robot will do in an hour compared to a 1500 watt booster cleaner. It will be impossible for you to quantify exactly what savings you would experience.....there are simply way too many variables.
    I personally like robots but I have a fairly large pool and they need to run for hours daily to keep my pool clean. You will have a different set of circumstances and will have to use some common sense and familiarization with the characteristics of each cleaner and then make your best decision.
    Aug 2013
    St. Croix, USVI
    11
    I have used Polaris 360's for over 15 yrs in three different pools two in Virginia and now on St Croix. I just opened my pool in the VI's and would not do without a Polaris 360. I would add a small filter to catch some the debris you might collect through the return pipe. I used 1' 1/2" line and it works like a charm at 15 PSI.
    Order a few of the most frequently replaced spare parts.
    Hoorah for polaris!!
    Marbelite 13K gal pool in Rain Forest St. Croix USVI (opened 08/04/13)
    Hayward 2030 cartr filter (225sqft) Hayward skimmers
    Lorenz Solar powered pump 4 Ecogreen PV panels 245W ea w A/C back up Polaris 360 cleaner w separate filter
    Location is 17deg 47' N Water Temp 82-86deg Ambient temp 75-90deg Rain Fall 60-90"/yr Altitude 615Ft ASL Sun Solar Exposure 11:34 to 12:25hrs/day
    mas985's Avatar
    Pleasanton, CA
    11,737
    Several people on the forum have used ThePoolCleaner with a VS pump with success. These cleaners use less flow rate (and thus less energy) than most other cleaners.
    Mark
    Aug 2013
    St. Croix, USVI
    11
    This is exactly what I did in three pools, a separate return line with a separate Jandy valve and a small filter. I can control how much pressure the Polaris 360 will receive (typically 15psi) and it works great. I am super pleased with Polaris.
