Results 1 to 8 of 8
Thread: cya: forum vs. manual
    Mar 2013
    south Texas
    10
    hi all,
    FC: 3
    CC: 0
    PH: 7.8
    TA: 70
    CH: 350
    CYA: 40 was wondering what you think about the different recommended levels for CYA. my Pentair manual says 30-50. but TFP says 70-90. any thoughts are appreciated.
    17,500 gal; intellichlor IC40; whisperflow 2-speed; CC200 cartridge filter; wet edge Antigua plaster
    17,000 gal. in ground, poured Jan. '13
    Pentair 200 CC filter
    plaster finish - wet edge Antigua
    Pentair whisperflow 1.5 hp. 2 speed pump
    Pentair IC20 swg
    Jun 2012
    Louisville, KY
    266
    Re: cya: forum vs. manual
    70-90 is much better for a swg. It won't have to work as much extending its life. The recommendations here are tested tried and true. They frequently conflict with "common knowledge in the pool industry". I trust my trouble free pool to these specs. That's why it stays trouble free.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I agree with spidey's assessment.
    In addition, the cynic in me wonders if the manufacturer does know something about cya effects and wants to sell you a new cell sooner since running at 40 ppm cya will typically mean shorter cell life (more hours sooner) than running at 70-80 ppm cya.
    Mar 2013
    south Texas
    10
    thanks for the insight folks...i'll be adding more cya tomorrow. by the way, does anyone remember the ratio for the FC to CYA in percent, I saw it somewhere on this site...from chemgeek perhaps? thanks again
    Pentair IC20 swg
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    For a swg you want to maintain a minimum FC level of 4.5% of your cya level. See: http://www.troublefreepool.com/chlor...art-t2346.html
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by staberg
    but TFP says 70-90
    The Recommended Levels for SWG says 70-80 and Water Balance for SWGs says between 70 and 80. Neither says 90.
    Most SWG manufacturers say something like 60-80 with 70-80 "ideal" or "best". Pentair seems to be the outlier. The reason for the higher CYA recommendation is that most SWG systems tend to be undersized and would not be able to output enough with the loss of chlorine from sunlight. Even if you purchased an over-sized unit to keep up, the greater SWG output will usually lead to a greater rise in pH, possibly due to both greater aeration from the hydrogen gas bubbles and from undissolved chlorine gas outgassing. Minimizing the SWG output by lowering chlorine loss via higher CYA therefore makes sense.
    Though you could go by the 4.5% rule, the Chlorine/CYA Chart is easier to use and a little more conservative (rounding up -- 5% with 4 ppm FC at 80 ppm CYA).
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Hmmm. The difference in "Recommended Levels" and the implied recommended levels for SWG pools in the "Chlorine/CYA Chart" never registered with me until now. Perhaps the table for SWG pools in the "Chlorine/CYA Chart" should be changed, eliminating the levels for CYA of 60, and leaving just those for 70 & 80. That could eliminate a possible source of some minor confusion.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    30,403
    With an accuracy of plus or minus 10 ppm (CYA test) at best, 60-80 works fine for an swg pool. 70 can be considered a "sweet spot" but there are many pools managed successfully by using the 60-80 range.
    90 ppm is not a TFP recommendation for all the reasons that have been hashed over here on the forum for years.
