Results 1 to 13 of 13
Thread: Pressure Gauge for Sand Filter Condensation Build Up/Leak
    I replaced a Pressure Gauge for my Sand Filter 4 months ago & every time it rains or in damp weather, condensation builds up under the Plastic Face Plate & it is very difficult to read. It clears up eventually, but it the PSI on the gauge is more invisible than visible most of the time. Did I buy a cheap gauge? Is there one I can buy that will never do this? I thought of sealing it with crazy glue, but have not tried that yet. I live in Florida, so it is very humid here. Thanks in advance.
    20' X 40' Rectangular Gunite Pool with Spa
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure Gauge for Sand Filter Condensation Build Up/Lea
    I would use the google forum search near the upper right of page and search for the liquid filled pressure gauge threads. A liquid filled gauge will last longer and not have the condensation problems your are experiencing.
    Wow! Never knew they existed. I found this great site. The only thing is the Increments of the Measurements are way too high. I need numbers like 10, 20, 30 so I can monitor 1 PSI at a time.
    Here's the Link I found: http://www.directmaterial.com/2_1_2_Liq ... pb254l.htm
    Thanks for the suggestion.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you keep looking I am sure you can find a more graduated liquid filled. I know for a fact they exist.
    Essential Links:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    A 0-30 psi gauge (which is available on that site) should have 1/2 psi increments (most do).
    On the Site the 1st one is -30 Hg to 0. Is this the one? I also would like one to go a bit past 30 like the one I have now which I believe goes up to 60. They don't show a picture of each individual Gauge & the different PSI Readings.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How high is your pressure going? Above 30 psi is too high.
    The one you would want is this one: DCPB254L-030 which is listed as:
    DCPB254L-030 2-1/2" Liquid Filled Pressure Gauges - Lower Mount - 30 Psi
    No. It does not go past 25 psi. And that's when I Backwash.
    Normal Operation is 17 psi.
    I just thought having the option of a 60 psi would be better in case there are any big problems. But I'm sure I'd know about it right away, if it ever went that high, even without reading the Valve.
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    May 2011
    Long Grove, IL
    117
    Quote Originally Posted by dino1956
    Here are a few available from eBay that are 0-30 psi and have nice big numbers.
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1242801029
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0786467242
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    Cool. Thanks Jay!
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Depending on what part of Florida you're in (whether or not you have one of these stores close by (no shipping cost)) you may be interested in this gauge as well. Don't know anything about the quality, etc. I just ran across it last night doing some looking. I like the less cluttered look of it.
    http://www.northerntool.com/shop/too...ct_48295_48295
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Wow. That's a beauty. I like it. Shipping is Only $5.99. So for under $20. still not bad as long as it lasts & works.
    What kind of Liquid do they use inside the Gauge?
    28,000 Gallons
    Sand Filter
    Rainbow Chlorinator
    Penair Pump
    Polaris 280
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Glycerin.
