Thread: Test numbers done...now what?
    Dont laugh im still learning
    Here are my #
    FC 4
    Cc 0
    TC 4
    Ph 7.8
    TA 90
    Ch 220
    Cya 70
    From the pool calculator I think this is what I should be doing...correct me if I'm wrong
    Based on my cya my FC needs to be at 5 so I need to add 38oz of 6% chlorine.
    I want to bring down my PH to 7.5 so I need to add 15oz of 34% baume muriatic acid.
    TA is ok
    Ch is ok. Although I have been told its recommended to raise. But I can't seem to find the product to do so any recomendations of what to purchase and where?
    CYA ?? Here it's rec to have at 30-50 and TF 100 instructions rec 30-80...so I don't know.
    My pool water looks clean, clear and blue as it should. My only issue is that my z bot vacuum picks up small pieces of the plaster pool...how can I fix this?
    Inground kidney plaster pool 30x17 with hayward superstar clear cartridge filter system, sta-rite max-e-pro 2 hp pump.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Test numbers done...now what?
    Things look pretty good.
    Your CYA is a bit high, but it could be manageable with using bleach. We like to see it in the 30-50 range. Maybe work on lowering it later.
    Keep your FC in 5-8 range and not below 5.
    PH is on the high end of the range. Lower it and see how stable it is.
    Not sure what to do about the vacuum.
    Jeff
    Isaac-1's Avatar
    SW Louisiana
    6,711
    For CYA we suggest about 30-50 for most manual dosed outdoor pools, with the higher end if it has a high level of sun exposure / sunbelt location, etc. 70-80 is suggested for pools equipped with SWG's (salt water chlorine generators) which constantly hyper chlorinate the water that passes through the SWG cell when it is in operation.
    Ike
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    If you only raise your FC to 5--you'll be at the MINIMUM! You should raise it at least to the target level and see how much you consume daily. Some of that is gonna burn off ya' know! You may need to go a tad higher than target.
    Quote Originally Posted by Isaac-1
    Ike
    Thanks that cleared it up for me
    Quote Originally Posted by woodyp
    That makes sense...I added more chlorine to get my target of 8
