Results 1 to 7 of 7
Thread: Turn off SWG and run pump for 24 hours after adding salt?
    Apr 2011
    Palm Harbor, Florida
    90
    I am not able to find where in TFP it says to turn off SWG, with pump running for 24 hours, after adding salt.
    Maybe I was imagining things, lol. What's the proper course of action to do after adding salt for SWG pools?
    Thanks in advance.
    Florida-style enclosure (lanai) housing 18,000-gallon outdoor in-ground salt pool/spa, PeebleTec finish. Spa water waterfalls into pool. Hayward model 17502 cartridge filter system, Hayward SP3400VSP EcoStar Variable-Speed Pool Pump. One skimmer, Baracuda Zodiac MX-8 cleaner. Palm Harbor, Florida
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Turn off SWG and run pump for 24 hours after adding salt
    Absolutely turn off the SWG when adding salt and let it circulate for 24 hours with the SWG off. Read the instructions for your SWG for more information. Our sensor was damaged by a worker for our pool builder when he failed to do this upon startup.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    The reason for the 24 hours is a safe number for all types of salt that may be used. Just like ComputerGuy said, the important part is that the cell is powered off during the addition.
    Pool salt dissolves very quickly but other types (i.e. softener salt) takes longer. The goal is to not expose the cell to any high concentration spikes.
    Here are a few links discussing the issue:
    brand-new-agp-swg-help-with-shocking-and-adding-salt-t47153.html#p383697
    adding-salt-t10292.html
    swg-setting-first-time-t33821.html
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2007
    Brisbane, Australia
    874
    are you starting up your pool or just topping up to increase salt level?
    i take it it's the later, in which case you don't have to turn it off.
    just add salt along the pool wall and brush it to mix a bit.
    if it's the former - most SWGs won't turn on with low salt anyway, they'll be just displaying low salt alarm.
    Apr 2011
    90
    Thanks all. I did indeed thought I saw it being mentioned somewhere here before. I just cannot seem to find where it said that.
    If the website maintainers/admins agree, I would propose that this bit of information be added to the following links:
    pool-school/pool_water_chemistry (in "Salt" section)
    pool-school/water_balance_saltwater_generator (in the paragraph where adding salt is mentioned)
    Maybe something here too: pool-school/salt_water_chlorine_generators
    Apr 2011
    90
    Quote Originally Posted by Strannik
    Yes, topping off - ie: adding a bag or two for salt (taking us from 2600 to 3100 with 2 bags of salt).
    So in those cases, we don't have to turn off SWG?
    What about running pump? I would imagine, long enough for all salt to be dissolved, which is pretty quick, correct?
    Jul 2007
    Brisbane, Australia
    874
    if you only adding salt to bring it up by 500 ppm i wouldn't do anything specific at all.
    just spread it around the pool and brush a bit to ensure it's not collected in one spot.
