Thread: newby with cloudy water
    Aug 2013
    Newport, NC
    4
    Hi all,
    when I say cloudy, its really a pretty blue! but I want sparkly clear like it used to be. ok, history.
    This is a early summer setup. Looked great till Chlorine got low, got algae. it never was real bad, as soon as I saw green coloration I added algae killer (don't remember what kind, pool store). algae went away but never became clear.
    Now I finally listened to your forum and got a TF100 as of yesterday.
    this morning results:
    FC = 0
    PH = 7.5
    TA = 190
    CH = 150
    CYA = 0
    Didn't text CC, since FC and CYA were 0 I didn't see the need.
    Pool Calculator (I THINK) suggests:
    62oz bleach
    5 lbs CYA
    29 oz of 31.45% 20(degrees?) Baume (Whatever the heck THAT is!!) hahaha
    and 163 oz Calcium Chloride
    does all this sound about right? if anyone has better suggestions i'm all ears. if this sounds good, what are the last two and where do I get them?
    Thanks in advance to everybody!
    Steve
    10.5k AG, Intex 14" Sand Filter, 1600 gph, SWG Auto/on Switch, 24' round 52"deep.
    30,424
    Re: newby with cloudy water
    If you are going to get your water clear, you will need to SLAM the pool. You are using the poolcalculator to bring it up to normal maintenance levels.....that won't get it.
    read "The ABC's of Pool Water Chemistry" up in Pool School.
    Than, read "SLAM - Shock Level And Maintain" in the How To section .
    Start the SLAM process.
    You do not need the two products that you don't understand. Disregard them for now but you need to learn in Pool School what they are and what they do in case you ever do need them.
    Aug 2013
    Newport, NC
    4
    thanks Dave.
    Aug 2013
    Newport, NC
    4
    In slamming, it doesn't say anything about adding stabilizer. with my cya levels at 0, do I need to add that also while I am SLAMMING? Or is adding that much chlorine over the course of a couple of days going to bring that up automatically?
    30,424
    Add stabilizer separately to about 30 ppm. There is no stabilizer in bleach.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would add enough stabilizer to get you to 30 ppm of CYA. The stabilizer will protect your chlorine from the sun.
    Adding liquid chlorine will not add any stabilizer. You have to add stabilizer on its own.
    Jeff
