Thread: Need help with PVC connections
    Today I pulled off the flex hoses that came with pool and ran 1.5" PVC. All went well until I started flowing water again and ALL the male adapters (at filter ports, pump inlet & outlet, return). I used PFE sealing tape on all the threads. So I thought maybe I didn't use enough tape....pulled everything apart, cleaned threads, ran 2x layers of tape...still leaking . Now I've got couplers everywhere and looks crappy plus the drips. Its definitely leaking through the threads.
    What did I do wrong? Too much tape? Not enough? Wrong sealant?
    Any help is appreciated.
    18x33x54 Resin Hybrid AGP, 16,800 gal, 1.5hp Pentair, 22" sand filter, Saltron, PVC plumbing, Main drains, wedding cake steps, TF-100, Installed August 2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Use a thread sealant rated for PVC pipe. The tape doesn't work so well.
    You can get it at any hardware store, Lowe's, HD.
    Jeff
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Need help with PVC connections
    rector Seal 5 comes in a yellow squeeze tube. At my Home Depot it was in the bottom row of the galvanized pipe plumbing fittings, across the aisle from irrigation and sprinklers.
    -- Guy --
    Thanks for the suggestions. Will try one of these tomorrow....fingers crossed.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    This is what the small package looks like. I post it as i was not expecting it to look like this... or be where it was.
    -- Guy --
