Results 1 to 9 of 9
Thread: Slam Question??
    Jul 2013
    Chicago IL
    83
    Slam Question??
    So my FC shock level is 13 ... Its at 13 tonight , now i should maintain 13 until the overnight chlorine drop is minimum 12?
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Slam Question??
    If your asking about the OCLT test, then FC of 12 would be your 1ppm loss over night.
    Jeff
    Jul 2013
    Chicago IL
    83
    Re: Slam Question??
    So in the morning if its lower than 12 i should raise it back to 13 everyday until its 12+ in the morning?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Slam Question??
    How long have you been SLAMing ? You want to test as often as you can and raise it back to SLAM level when it falls below SLAM level.
    Your done SLAMing when
    1 water is crystal clear
    2 CC of 0.5 or less
    3 OCLT test of 1 ppm or less
    Jeff
    Jul 2013
    Chicago IL
    83
    Re: Slam Question??
    My water had been a little hazy , been losing about 3ppm per night
    Just started slam today , added liquid chlor. FC to 13 . My CC has been 0.5
    Going to test in morning and try to keep it at 13.
    Jul 2013
    Chicago IL
    83
    Re: Slam Question??
    Keeping FC at 13 is safe to swim??
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Slam Question??
    Ok. Make sure you read pool-school/shocking_your_pool and follow it to the T.
    Any questions ask away.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Slam Question??
    You can swim in FC levels up to SLAM level. Unless water is so cloudy you can't see the bottom. Safety first !!
    Jeff
    Jul 2013
    Chicago IL
    83
    Re: Slam Question??
    Thanks again
