Results 1 to 19 of 19
Thread: Very first tests with TF-100 . Very high CYA, CA and FC
    We recently became owner of a 15K gallon pool (guesstimate based upon volume). And in process of learning to maintain it.
    Last week the pool started turning green for second time in one month. Last time this happened we called the pool services. This time we thought of fighting it ourselves. The first thing we noticed that it was out of Chlorine tablets and we used tablets we bought from Costco. Then we used Leslie's testing services and "shock" advice. Algae started going away but pool was not really clear.
    Then I discovered troublefreepool and did following
    -Shock using Great Value bleach 8.25 (45 ounce based upon 60 CYA reading by Leslie).
    -Washed the cartridge and
    -Cleared clogging from Polaris 360, so it started moving again.
    The pool improved overnight. Leslie's reading suggested:
    FC = 5 ppm
    pH = 7.5
    TA = 90
    CYA = 60
    Today I got TF-100 kit and here are the results:
    • FC = 12 ppm
      TC = 14 ppm
      TA = 110
      pH = 7.5
      CH = 800 ppm
      CYA = 100
    I repeated FC and CYA tests but got same results.
    Pls advice as to whats going on. And what should be next step for us?
    JFYI,The pool is used approximately used 2-3 times a week.
    Also from pool school I understood high CYA is caused because of CL tablets. Should we even be using Chlorine tablets at all?
    15K Gallon, Plaster, 190 sq.ft. Cartridge Filter, Chlorine In-line feeder, 3/4 HP Hayward Booster pump,
    1.5 HP Hayward Super II Pump, Polaris 360 Vacuum
    22,551
    Re: Very first tests with TF-100 . Very high CYA, CA and FC
    Welcome to TFP.
    You've already done the best thing you can do. Starting to read pool school and getting the TF-100.
    Unfortunately you need to drain about half of the water to begin with.
    Once you do that SLAMing the pool will be much easier.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May be dump question.
    Any howtos on how to drain the pool? I see lots of levers but not sure which way to pull. I can go always trial-and-error path.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Welcome aboard.
    Just like Bama said, you are on your way to a Trouble Free Pool. Do the drain and refill and report back. Oh....stock up on some more of that Great Value bleach.
    Quote Originally Posted by ceo_nikka
    A resounding no. I know.... seems like a waste of the tablet feeder.
    As you've learned from Pool School thus far...the trade off for solid chlorine products is either upping CYA or CH, neither of which do your current levels allow for more of.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Not a dumb question.
    The best (and probably your only) way is to rent, borrow or buy a submersible pump.
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Do cartridge filter setups not have a way to vacuum to waste?
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by Jeetyet
    Unfortunately, they don't. Since backwashing is not a function of cartridge filters, they are not installed that way.
    Some (including mine) have a small hose bib installed to the plumbing after the pump.... but that can be a very long process to drain a pool with a garden hose.
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Thanks! I learn something new every day at this place.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Home Depot rents trash pumps that will take care of the drain in about three hours.
    I have done some drains with garden hose siphons where you place the end in the pool and at the hose bib you turn on the water and when the hose is full of water, you turn off the bib and then hake the hose off the bib and it will siphon the water out of the pool. If you start two to here hoses, it will drain the amount need in a day or so but watch how much you take out.
    -- Guy --
    Thanks Guys!!
    Next task is to call the city and ask for estimated water bill for 7500+ gallons.
    And of course start draining...
    30,424
    Probably less than you think. Water costs nationally seem to average between 5-8 dollars per 1000 gallons.
    Well the news is that the Stage 3 water restriction are in place. Hence we cannot drain and refill the pool.
    I have to wait till end of this month.
    Is there anything else we can do in the interim?
    Aug 2013
    Nashville, TN
    30
    ceo_nikka
    Posted: August 30th, 2013, 10:13 pm
    If you try the. "Trial and Error" method, you should turn off your pump between lever moves. You want to make sure that you don't cause too much pressure build up. You can cause damage to the plastics.
    10k AGP 19" sand filter 1hp pump
    Aug 2010
    Dallas, TX
    4,052
    With a pool of that size, a partial drain and refill probably won't send up any red flags. I use way more than that on a monthly basis.
    Finally, able to find spend some time and drain half of the pool.
    Latest reading
    FC = 1.5
    CC = 0
    CYA > 100
    PH = 8.2
    TA = 120
    What should be next step? Fill the pool or add 120 oz liquid chlorine first?
    May 2013
    Bay City, Michigan
    283
    Both.
    You need chlorine in there to keep bad stuff from happening. Since it's partially drained? I assume you cannot run your pump so should stir it up somehow. (Brushing, someone swimming, anything)
    Need to get it filled back up to dilute the CYA down and get your filter running again.
    Once you get it filled back up and filter running, check you PH and lower it if still high.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I would drain it anyway !!! Despite any water restrictions..
    Tell them if you dont you will have a green mosquito infested west nile generator !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Quote Originally Posted by scott.MI
    Both.
    Oops. I had pump running. Didn't realize it should be off? Just did that.
    May 2013
    Bay City, Michigan
    283
    I'm not familiar with your pool, so that comment was based on an assumption. I was assuming your returns would be above the water line and the pump would be off. All pools are different so if you can safely run the pump, that's good.
    With that in mind, if you can still filter/circulate water. Get chlorine in there before it starts going green on you. Lower your PH. Unless your waiting for the end of the month still, fill er' up.
