Thread: I need a new 2000 Sweetwater Bahia Circuit Board
    My Circuit board took a dive today. My heater is not working and you can see the board where the power comes out of the board to the heater is cooked. My board is a 6600-204 but I cant fine one. They recommend the 6600-288. Is this true? I have a circulation pump on it.
    Mike
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: I need a new 2000 Sweetwater Bahia Circuit Board
    Welcome to TFP!
    I don't know if someone here will know the answer to your question, but perhaps someone will know.
    ok thank you
    jerrypar72's Avatar
    Nov 2007
    Phoenix
    32
    My Sundance Caprio ST spa has the same problem! The board relay that the heater is connected to exploded, and I now need a new 6600-286 circuit board. I found a replacement board here in Phoenix for $400.00, but I found the board on line at www.spaandpoolsource.com for just $239.00. Does anybody have any experience with this spa parts company? I'm wondering if the board is an aftermarket part? Would appreciate any info on this company!
    11,000 gallon Tahoe blue pebble tec, PCC 2000 in floor cleaning system, with two Pentair 1.7HP cleaning pumps, and a separate pump for water feature, Frog chlorinator, 60 SF DE Filter
    yes, i am in chandler, az. i bought mine from that website and it works great! just make sure you get the correct chip in it. or use your old chip.
    Mike
