Thread: Here are my latest test results!
    Jul 2013
    Lake Charles, Louisiana
    32
    What do you guys think? Do I need to do anything?
    FC 3.5
    CC 0
    TA 80
    CH 150
    CYA 20
    pH 7.8
    CL 5
    Br 10
    Salt 3300
    IG vinyl built 7/1/13, 30,000 to 30,500 gal
    Pentair TA-100D Sand Filter
    Hayward T-Cell-15 Chlorinator
    Pentair Superflow Pump 1.50 hp model # 196239
    Hayward Goldline Pro-Logic
    30,413
    Re: Here are my latest test results!
    How does your water look?
    Jul 2013
    32
    Crystal clear
    38,262
    Then I would suggest raising the CYA a good bit since you have a SWG which will allow you to lower the output on it as well.
    And don't let the pH get any higher.
    Butterfly's Avatar
    South Carolina
    10,045
    What they said ^^^^^
    .....and you can ignore the BR on the OTO/pH tester. That is for bromine and you have a chlorine pool. Most of us did the same thing when we first started with the tester
    Your #'s look pretty good! But if you are going to run the SWG, the CYA is low, as Jason mentioned. Here's a link to Recommended Levels from Pool School: pool-school/recommended_levels
    You're done SLAMing when:
