Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: New POOL in Central Texas pics UPDATE 12/18/13
    Well new to TFP, and fixing to start a new pool.
    I have had 3 estimates and all are pretty close. 50k to 60k
    The one below is probably going to be the PB we go with.
    18x36 gunite 3.5 to 6ft deep
    stone scape plaster 1/2 to 1inch thick
    3 bar stools with tile seats, and tile bar top
    hot tub 7ft
    12 inch tavertine
    all Hayward equipment, variable speed pump, sand filter, pro logic Ps8 salt system w/computer software, 2 actuators and wireless antenna
    and remote control
    washed agregate concrete 700 sq ft
    1 color logic spa and 2 color logic pool light
    all plumbing schl 40 pvc 1 1/2 to 2inch
    Hard plump with individual dual suction line for future jets (gonna install Laminars later)
    was gonna get a fire pit but the cost was 4,800.00 extra
    break down in cost
    pool 32,850.00
    Ps8 computer and software 3,500.00
    spa with heater 12,600.00
    stone scape plaster for pool 3,500.00 and spa 800.00
    Never had a pool only know what the PB's have told me.
    any input would be greatly appreciated! Thanks Jeff
    Suppose to have the bar top in tile like this one
    38,524
    Re: New POOL in Central Texas pics
    Welcome to TFP!!!
    These computer models are amazing compared to what I saw over 10 years ago at my first house / pool build.
    thank you,
    I hope to get a final pic of the design after the changes
    Should I get extra wire for the PB to lay for future projects (Speakers, LED lights, Laminars, sprinkler system in planters)
    Or wait and do it after its built.
    I am a DIY kind of guy, but never with a pool.
    38,524
    Depends on your access to places where you want the wire / pipes run. I would not want to have to tear up the deck just to run some sprinkler lines or speaker wires.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    That's a lot of stone exposed to a salt pool. Salt and stone don't get along well. Many pool builders say "its no problem, just seal the stone". It's no problem for them since they will have cashed your checks and your warranty will be over as the stone erodes away due to salt exposure.
    I've watched my neighbors' stone erode and degrade after several years exposure to salt. My pool builder was honest and said "stone or salt, pick one, but not both". I picked salt and my pool was built with no natural stone surfaces anywhere. Stone looks great and its cheap in Texas, but its all limestone and is easily damaged by salt. Pool builders tell customers that this is a harder stone and its no problem, but unless they are using granite, it will eventually be a problem.
    chiefwej
    Apr 2012
    Klein Tejas
    249
    I agree with Chief on the flagstone. My friend had a salt pool with "Oklahoma Flagstone".
    The coping (stone) had to be replaced after two years.
    It's a great looking pool but it's straight chemical now.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    what other coping should I use, or maybe just use chlorine
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Quote Originally Posted by J.T.
    thank you,
    I had my PB lay conduit under my deck for this reason to several areas. I also had him run water/gas/drain/elec for a future outdoor kitchen. Didn't want to be ripping up the decking in a year or two.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by JtothT
    I eliminated the coping and went with a cantilevered edge. The concrete deck just extends about an inch over the edge of the pool. With a stamped concrete deck it would be easy and save on cost. There are several other options if you want a coping, just don't use natural stone.
    As for giving up the SWG, I wouldn't give mine up for anything. It makes pool maintenance so much easier and the water feel so much better.
    chiefwej
    Re: New POOL in Central Texas pics UPDATE 10/23/13
    Well its been a while but got the hole dug and formed then rain like mofo!
    But just got the forms fixed and steel went in this morning!
    Plumbing tomorrow, Gunite Friday
    Went with 18X36 instead of 18X32, and Ps8 computer system, and 2 color Led pool lights
    Changed the coping also, not sure what its called but will ask. That's the extent changes so far.
    Any advise or suggestions would be taken to the heart Thanks
    Sep 2013
    Grand Prairie, Texas
    121
    Looks great!!
    "Rain like mofo"....lol, no kidding. We are building in DFW area & rain has held us up. Rain is in the forecast again!!! Ugh!
    Tracy
    35' X 19' pool (pool depth: 3.5', 5.5', 4'. Perimeter 97) 2 HP Jandy (2 speed)
    Spa 9.6' X 7.4' (10 jets total- 4 on circ, 6 on 2hp booster, 6' cascade spillway to pool). Heater: 400 BTU LXi
    Tanning ledge and benches covered with stone. 2 LED pool lights, 1 LED spa light.
    PebbleSheen finish in Aqua Blue
    30" gas fire pit raised 18".
    Well they laid some PIPE yesterday! And Gunite this Morning, Starting to look like a pool now.
    5 Trucks Later, 60 yards..Now its time to water the pool so it will grow!
    Casey's Avatar
    SW PA
    10,461
    Nice pool!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, it will be. Love it!
    Essential Links:
    Now I know why there is holes in the bottom of pool, for ground water to enter.
    More rain and now pool is half full.
    I assume when plaster is sprayed this will water proof the pool floor?
    They are supposed to start coping Thursday.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yes, they will pump out the groundwater and seal up the holes when the plaster goes in.
    Jul 2013
    Prosper, TX
    133
    It's a pretty cool process to see happen. Enjoy.
    18,600 gal, IG, Jandy 60 sq ft DE filter, 2HP VS pump
    Stonescapes Tahoe Blue mini pebble
    Re: New POOL in Central Texas pics UPDATE 11/18/13
    Well been a while, but progress is beginning to happen.
    Coping , rock work and tile!
    Sep 2013
    121
    Looks great! I especially love the tile on the spa!!
    Tracy
  20. Back To Top    #20
    Bar top and bar stools done.
