Results 1 to 7 of 7
Thread: Low Acid Levels
    May 2013
    Washington, Il
    40
    Low Acid Levels
    So, after my first year of running my pool here in Illinois and subscribing to this forum it is all starting to make sense (sometimes it takes a while for me to grasp concepts without actually experiencing them). Here's what happened this year: I started out with acceptable ranges of everything but CYA (which was 90). Over the course of this year I've run through a LOT of pucks in my chlorinator. When it was hot (not very often this pool season), I had to add liquid chlorine on top of the pucks running my pump constantly in order to keep algae away. My pool is crystal clear now with just pucks and has been for nearly a month; however, my acid and TA levels have dropped like rocks and eyes are irritated when swimming (but man is it clear water). So, my overall understanding is that the pucks have lowered my acidity, lowered my TA, and raised my CYA (all bad things). If I fully subscribe to the methods shown in this forum I will be using only liquid chlorine, sampling more often, and not using pucks at all. I will need to remove about 1/3 of my total pool water before winterizing and then starting with fresh (well) water next year I will need to fully subscribe to the methods I mentioned in the last sentence. Make sense? Am I missing anything???
    40,000 gallons (20' x 40'); IG; vinyl liner
    sand filter
    BBB method for 2 full seasons
    tf100 test kit
    central Illinois
    Jun 2012
    Louisville, KY
    266
    Re: Low Acid Levels
    That's it. With the heavy puck use your CYA is likely much higher than 100. By "low acid levels" do you mean low pH? Can you post a full set of test results? Having your TA higher will help with the pH as you are aware the pucks have CYA which is acidic and will lower pH and TA over time. Both of which can be corrected easily with borax (raise pH) and baking soda (raise TA).
    I'd be more concerned about CYA and FC levels to maintain a sanitary pool. If your CYA is over 100 you're going to have to drain more than 50% of the pool to get to the recommended 30-50 range.
    FC/CYA chart
    pool-school/chlorine_cya_chart_shock
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Jul 2013
    Central New Jersey
    55
    Re: Low Acid Levels
    Just on a technical note the pucks have actually raised your acidity, the lower the pH the higher the acidity the higher the pH the more basic. Everything else is spot on.
    26K Gallon, IG vinyl
    1.5 HP Hayward Super Pump, DE Filter 36 SqFt
    Older than time TELEDYNE LAARS HEATER (removed from system for now)
    22,548
    Re: Low Acid Levels
    Spidey gave you good advice. If by low acid levels you meant low pH, that's actually high acid level. 7 pH is neutral. Lower that 7 is acidic and higher than 7 is basic. We try to run pools slightly basic, as in 7.2 to 7.8 pH.
    If you're close to closing, you can drain some water now and then drain whatever is required next season to get your CYA about 50 ppm.
    Oct 2012
    Maricopa, Arizona
    109
    Re: Low Acid Levels
    I hope this is the correct forum to post this question. The issue I'm having is also a low cyanuric acid reading. Extremely low, like @10 or less, should be around 60, according to pool supply store I had test the water. This is 3 weeks in a row it has tested so low. The guy first thought I might have a leak causing it to be so low. I contacted the company that installed the pool. Their response was if there was a leak, I would have noticed a higher water bill. They said to get the acid level back up to where it should be and see what happens in a couple of months. If there's a leak, it should go back down. I went back to the pool supply store and the guy said to use a gallon of water conditioner and see how much that raises the acid level. I probably will need to add more but he wanted to see where the level was after adding the conditioner. That's where it stands right now. What's bothering me is even if we get the level back where it should be, what caused it to drop so dramatically in the first place. Any ideas or suggestions will be appreciated. TIA
    Pool facts: SWP, 10,000 gals., inground, 3.5 years old All other levels on the last test where fine except for the acid @10 and the pH @8(a little high).
    Inground SWP, 10,000 gals., Pebble Sheen, Hayward pump cartridge filter, Aqua Rite SWG, year installed 2011
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Low Acid Levels
    Quote Originally Posted by birkesl
    Since you now understand the risks of using pucks and how they raise your CYA , I'm wondering if you can just use the winter's rain and snow to help you exchange your water a bit before spring? Do you cover your pool? Can you let the snow/rain fill it while you also backwash some out now and then?
    Re: Low Acid Levels
    Welcome to you, aztony!
    Pool store results are sometimes inaccurate, and CYA is a test that they are more likely to get wrong than the others.
    I recommend getting one of the recommended test kits: pool-school/pool_test_kit_comparison, and checking for yourself. Then you'll have reliable information and can make a solid decision on what to do next.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
