Thread: Pump no go - even with new capacitors
    TheLoneHoot's Avatar
    May 2013
    JAX, FL
    15
    Split by moderator from HERE. Please start your own thread to avoid confusion. Thanks, jblizzle
    I'm having a similar problem with a regular single speed motor. I got a brand new capacitor and installed it. The pump is still making a loud humming noise and won't run. the impeller is totally cleared of debris and spins easily. The pump/motor is only about 2 years old.
    Any thoughts on what else it could be?
    My pool is turning very green and thanks to a recent monsoon is also full of sand and other particulate matter.
    -Austin
    15,000 gal (I think) sort of "hexagonal dogbone" shaped pool built in 1996
    Hayward Super Pump, Cartridge type filter, 1HP motor (new as of 31 August 2013)
    Hayward Aquadroid cleaner (original model) totally rebuilt except for shell in last year or so
    [center:1mx1gn4d]Pool (p?l): n. a hole in the ground into which one throws vast sums of money[/center:1mx1gn4d]
    [center:1mx1gn4d]Since I'm always asked:[/center:1mx1gn4d]
    [center:1mx1gn4d]* * * * * * * * * * * *How's the weather in FL?[/center:1mx1gn4d]
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Re: Pump not starting - even with new capacitors
    Quote Originally Posted by TheLoneHoot
    If you energize it and can spin it by hand and it runs, check if it uses a centrifugal switch.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    May 2013
    JAX, FL
    15
    Quote Originally Posted by nedchavez
    In my case, the guy with the single speed motor, it's not running. It just makes a loud hum or buzz. So it spins freely, has a good capacitor, and even if I turn it on and try to spin it by hand while it's buzzing it never "catches" and runs.
    I'm not sure if it has a centrifugal switch or not - I'll look over this thread and see if the location of one is mentioned.
    Pretty sure I'm just going to have to buy another pump. It's getting ugly out there at my pool and my wife's pretty anxious for me to get this resolved ASAP. But I'm still going to be curious about what caused a 2 year old pump to go bad.
    -Austin
    nedchavez's Avatar
    Jun 2012
    111
    Re: Pump no go - even with new capacitors
    If it doesn't " catch and run" when you spin it, the motor probably needs to be replaced. It sounds like the run winding is bad.
    May 2013
    JAX, FL
    15
    Yep, that's what I just got done doing about 15 min ago - just got out of the shower from that little workout (bending over and working those mounting bolts in 90°+ temps with 60% humidity). But yeah, I just bit the bullet and replaced the motor (and shaft seal of course)... $256!
    But it also turns out I was TOTALLY wrong about my motor power and age... I thought it was ½HP and only 2 years old - nope... 1HP and 6 years old. Man time flies - both my wife and I thought it was only 2 years ago that I replaced that motor. We've only been in the house for 7 years.
    Anyway, problem resolved.
    -Austin
