Thread: Adding a lighting niche?
    I have wall mounted, no niche type light in my pool. I have an inground pool with a liner. Is adding a niche something that could be done? Would it involve digging around the outside of the pool to get too the backside of the wall? Or is this something that could be done from the inside only? I already have electric running into the pool for the existing light.
    SWG Pool Pilot Digital, In Ground pool, Surface is coral rendered. Was done in 1998.
    Pool Volume: 25,000 US Gallons, Size is roughly 15' x 30'
    Filter: Cartridge
    Pump Size: HP 1, SF 1.1
    No aerator
    22,550
    Re: Adding a lighting niche?
    Adding a niche to an already built pool is a pretty big job. It does require getting access to the back of the wall, which means tearing up decking. If you have poured concrete, a section will have to be cut and removed.
