Results 1 to 9 of 9
Thread: Test results ...still little cloudy, clarifier??
    Jul 2013
    Chicago IL
    83
    5300 gal AG, Black Diamond Cartridge filter
    FC-7.0
    CC- 0.5
    PH -7.5
    CYA - 30
    TA- 130
    Cleaned filter ,Vacuumed ,been running pump about 10hrs a day ,just cant seem to get the hazyness out from underwater looking across the pool.The water IS clear ,just not crystal clear .
    I know from posts Clarifier is frowned upon....but should i give it a cup or will it make it worse?
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Test results ...still little cloudy, clarifier??
    Has it ever been crystal clear, or are you at the end of a SLAM and trying to get it crystal clear for the first time?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Rynz
    Do you know whether or not the product will work? If it will, is a cup the right amount? Is a quart the correct amount?
    It's my opinion that if you can't answer these questions definitively before you add it, you shouldn't put it in your pool. That is why these products are frowned upon here.
    Essential Links:
    Jul 2013
    Chicago IL
    83
    At the end of a Slam trying to clear .....I was losing about 3ppm per day, slam'd , chems seem fine now,pool is clean ,no leaves or dirt , just left with a haze underwater
    I have a gallon or so of HTH Clarifier , never used it. Not sure if i should
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I think you just need some more filter time. Cleaning up the haze can take sometime. POP !
    No need for the clarifier.
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by pwrstrk
    ditto
    Also, there are 3 tests to pass for completion of the SLAM process, and having clear water is one. You are not quite done. See red lines in my sig.
    You should see daily improvement and run the pump/filter 24/7 until done. Are you brushing daily, too?
    You're done SLAMing when:
    Jul 2013
    Chicago IL
    83
    I stopped slam after 2 days after about 2 gallons of chlorine when chlorine started to hold , i vacuum daily but dont really brush , i take like a hand towel and completley wipe down the inside of pool once a week. Looking down from above you can clearly see bottom , its just when underwater with a mask on looking across pool, there is a haze.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Brushing is important. Keep pump running 24/7. I take it you passed OCLT test. Maybe bring it back to shock level to make sure everything is killed off.
    Keep filtering 24/7. You'll get it.
    Jeff
    Jul 2013
    Chicago IL
    83
    Will do Thanx
