Thread: TA
    May 2013
    Cyprus
    159
    TA
    Hi
    been meaning to ask, in the suggested levels for TA it states 90+ what does the plus mean.?
    Thanks
    Living in Cyprus
    Still enjoying life
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: TA
    It's "70-90+" which means that the recommended range is from 70-90 for non-SWG pools using bleach (or chlorinating liquid or Cal-Hypo, not Trichlor), but it is OK to have a higher TA than 90 ppm (that's what the "+" means) if that is needed to keep one's pH stable (usually though, the TA needs to be lower to prevent the pH from rising). If the CH and pH are on the low side of the recommendations, then the TA can be on the higher side.
    May 2013
    Cyprus
    159
    Re: TA
    Thanks Ta
    Living in Cyprus
    Still enjoying life
