Results 1 to 10 of 10
Thread: Need help with vacuum and skimmer for AGP
    Aug 2007
    Surrey England
    30
    I have an agp 18'x12' and am on my 2nd season. I gave up on the little pump that originally came with my pool and this year I am the proud owner of a sandfilter/pump and a heat exchanger. The heat works brilliantly. I dont see too much happening in the water with the pump though (1/3 hp). I tried to hoover the dust from bottom of pool but the 1 1/4" hoses that I use outside the pool do not attach to the inside of the pool as the connections are exactly the same size. I though I would be able to just push the hose onto the pipe. I did hold it flush to the connection and the suction worked fine but I cannot move much in this manner. Can someone please tell me what I need to buy to connect my hose to the inside of my pool. And would this be the way I connect a floating skimmer too. I'd appreciate any help offered.
    Oval 18'x12' Quick Up Pool. 16" Sandfilter. FSP400 3/4hp pump. Duratech3 heat exchange pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Need help with vacuum and skimmer for AGP
    "Waste" seems to be the resident pool guru when it comes to equipment. If someone who "knows" is not along shortly to advise, send him a pm with this thread and ask him if he has any advice that he can respond here?
    Sorry I can't help!
    Benton, La
    148
    My vac hose has a fitting thing on the end that goes through the skimmer opening of the pool & sticks into the hole in the bottom of the skimmer.
    I just realized you have a smaller pool that came with a small pump. What type skimmer do you have?
    Aug 2007
    Surrey England
    30
    bassadict69 and frustratedpoolmum
    Thank you frustratedpoolmum, I will use that contact if I cant solve.
    Bassadict69 my pool didnt come with a skimmer. I have looked on the internet and think I know what to get to put a vacuum and skimmer together and am planning to go to pool shop this morning.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Angela, welcome to TFP! I'm thinking that you are 'across the pond' - nice to add the international touch to the site As you think you may have found the parts to convert to a skimmer and vac, I'll only say that all the specialty adapters I'm familiar with are 1 1/2" and a bushing (or reducer) would need to be used on anything I might suggest (I know there used to be 'retro-skimmers' that would work off a wall suction - but I haven't seen one of them in over 20 years - I hope you were able to find one!) If you've any questions once you receive the equipment, don't hesitate to ask!
    Again, welcome to the site and we'll be here for you when you have a question
    Luv& Luk
    -Ted
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Waste were the skimmers similar to this?
    Here's the link to the product(I hope I'm not breaking any rules).
    http://www.intexstore.com/ProductDet...CategoryID=109
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Mar 2007
    4,160
    That looks to be very similar to the old ones (of course the old ones were steel piping ) The way these work is to have a hopper and a floating ring, just below the surface, to 'skim' the surface and a basket to catch the 'stuff' from the surface.
    With only one suction source, a modification to the setup may be necessary to keep the vacuum head from just sticking to the floor, but we can deal with that when the issue arises
    Launboy, thanks for the link!! I think it may help MANY folks with similar pools in the future 8)
    Luv& Luk
    -Ted
    Jun 2008
    Marana, AZ
    347
    It's very easy. My auto pool cleaner came with a valve that adjusts to allow a variable amount of suction, but there was still too much suction at the setting that allowed the least amount of suction. So I went to the pool store, looked at their wall of vacuum cleaner replacement parts, found another valve, then put the two valves in series. Presto! I have a valve set up that allows me to have the correct amount of suction to my cleaner. So you just need to find a pool store that carries cleaner replacement parts and look for a variable valve (the one that goes in the water, not one for outside. It will be PVC, probably white or tan.) The valve I got from the pool store is a hayward, btw. My auto pool cleaner is a baracuda.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Jun 2008
    Marana, AZ
    347
    Quote Originally Posted by angela
    Sounds like you have either two male ends or two female ends. If you have two female ends, you need a connector piece with two male ends, or if you have two male ends, you need a connector piece with two female ends. You can probably find those in home depot (in PVC fittings) or with vaccuum replacement parts in your pool store.
    Hayward sand filter
    Aug 2007
    Surrey England
    30
    OK thank you everyone. I found a hose and vacuum head but I have a very odd connection on the inside of the pool - completely different to the outside connection. I dont think they ever meant me to hook anything up to it. No thread on either end (hose either). Found a black rubber connector in B&Q. Its about2 1/2" long and is big enough one end to fit snuggly over the connection on the inside of my pool. The other end is smaller and fits snuggly over the hose. The suction of the return keeps the whole thing together. Works Brilliantly. Used all my spare money up now so I will chase up the skimmer later in the year - the ones suggested looks great.
    Thanks everyone.
