Thread: Help needed setting up pool audio
    Currently I have 4 rock speakers around the pool and 2 Bose 151s under the soffits at the house. I am running an old bookshelf system and a 4 zone switch. I have a RCA cable from the video input to the headphone jack on an old windows xp machine. I am able to play radio from the bookshelf system and pandora or iTunes from the computer. I would like to be able to AirPlay somehow. I have searched for a 2 channel receiver with networking and AirPlay but I can't find anything. Any ideas how to do this?
    16x24 IG Vinyl Liner coming soon!
    Re: Help needed setting up pool audio
    Not sure if I'm missing something in your description, but... you can use an AirPort Express (http://www.apple.com/airport-express/) to do this. AirPort express has audio out that can route to any appropriate input on your existing amp/receiver. I'm not sure if a Windows PC will support AirPort, but if so, you're done. PC will find AirPort wirelessly, and you can direct ITunes to send it's output to the AirPort box (aka your stereo), local PC speakers, or both. I do this now, but use an iMac as my music hub. I especially like it because I can use an Ipod touch or IPhone from the pool area to run the "remote" app, that gives me full control on playlists and volume outside.
    22,000 IG Vinyl with spa overflow to pool. 1.5HP Pentair for main pump. 1.5HP Pentair for spa jets. Polaris 380 with dedicated pump. Pentair DE filter 48 ft2. Installed 2007;
    Quote Originally Posted by tmarks66
    So I could connect the AirPort Express to my receiver and stream from my iMac or macbook pro in the house instead of the old pc in my garage? That would be awesome and I will be able to play from my iPhone too!
    Thanks for the head up, I'm not sure how I ever missed this lol
    Apr 2013
    Destin, Fl
    38
    Check out this link. XBMC can be loaded on a Windows or Ubuntu machine and you can Airplay to it. We sit out at our pool and use Airplay to stream music from our phones, to the computer, to the speakers outside.
    Best of all - it's FREE!
    our-outdoor-music-solution-t63748.html
    28,000 Gal, IG Gunite/pebble, Filter Sand Dollar SD-80 (75 GPM), Pump TBD, Install Apr 2013, Ozonator
