Thread: Hose Cracked or Cut, Filter Ran Dry
    Hello, I new here so please forgive me if I'm not posting in correct place. I wanted to show a picture of my pump hose. I woke up to a cut, or tear in it & a half empty pool with the Sand Filter Pump Running Dry.
    Can anyone tell me if the Crack in hose looks like a normal tear from wear? It looks to me as if it were cut intentionally. If so, I'll file a report. I'd hate to call the police if it were from normal wear. The only other hose I've had to leak in the past, had merely a pin hole.
    Thanks for the advice I found on this site regarding what to check for Pump Damage. I see no visible damage to pump.
    Filling pool new & then will replace hose & try pump.
    abg intex 16' x 48" ultra frame pool with dual suction
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hose Cracked or Cut, Filter Ran Dry
    Welcome to TFP!
    Looks like a normal failure to me.
    Thank you. I'm relieved it wasn't intentional. (I found a cigarette butt & some chewing gum in yard also, hopefully just critter litter, lol).
    22,544
    I agree, that looks like fatigue, not smooth enough to be a cut.
    Thanks Much! I feel so much better. Pool is almost full again,
