Results 1 to 9 of 9
Thread: After closing...
    Jul 2013
    St. Louis County, MO
    63
    After closing...
    I've been taking care of my pool this Summer thanks to this forum. I am going to have a pool company close the pool for me, though. My pool currently uses a tarp cover with water bags. I had a some questions for maintenance after the pool is closed:
    • * I understand the need to keep water off the cover and keep down the accumulation of leaves. I have used a non-automatic little giant for water removal in the past, but it is VERY slow. What are some recommended automatic cover pumps that would work reasonably well on my size of pool? The Rule 1800 looked good, but there are a lot of people on Amazon that seem to have had horrible problems with it...
      * The pool company offers a monthly winter maintenance package to clean off water and debris (which I plan to do myself with a pump and a leaf blower) and add chlorine and algaecide "to help maintain the water chemistry". I'd like to take care of any of this myself. Is the addition of chlorine and algaecide a good idea? If so, how should it be done without the pump running? What level of chlorine should I maintain, and how do I determine whether I need to add algaecide?
      * Should I shock my pool prior to closing as some of the do it yourself postings suggest, or should I just let the pool company do their work?
    Thanks for the help!
    --Al
    My Pool: IG 31k Gallon vinyl liner (41'x16' w/ 12'x16' "L" leg; avg depth 6' in main area, 3' in leg), Pentair IC40 SWG, Polaris 380 Cleaner, Pool-o-matic auto filler, TF-100 Test Kit w/ Taylor K1766 Salt Test, Sand Filter, 1.5 HP Pentair SuperFlo VS (#342001) variable speed pump, Rheem/ Raypak 266A.
    22,551
    Re: After closing...
    When seeking winterizing advice it's nice if you post your general location.
    I just siphon off as much water as I can and then use a leaf blower to blow off the rest and the leaves.
    If you can't siphon it off then using a pump would be a good idea. It's sad about the Rule pump because they make some of the best marine bilge pumps. I don't know why they can't get the pool cover pump right.
    The Wayne pump looks promising. I'd probably try one of those.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,624
    See if Attwood makes one. Rule has been around forever--hard to believe.
    Jul 2013
    63
    Sorry, I'm in eastern Missouri in the St. Louis area. I added my location to my profile.
    --Al
    Little Giant 599008 115 Volt RS-5 Piggyback Diaphragm Switch
    by Little Giant
    http://www.amazon.com/Little-Giant-RS-5 ... m_sbs_hi_3
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Jul 2013
    63
    Thanks for the replies about the cover pump. I appreciate them .
    Can anyone comment on the second part of my posting? Do I need to be adding chlorine and algaecide during the winter as the pool company says they will do (for a fee...), or is this a waste of time? If so, how does one go about it? I can test for chlorine with my test kit, but does it need to be higher or lower than when the pool is open? How do I determine if the algaecide level is correct?
    Thanks--
    Al
    22,551
    If you have an opaque cover you won't need to add chlorine beyond the initial closing dose and you won't need algaecide at all. It's just insurance.
    May 2013
    Massachusetts
    148
    I never add chlorine after closing but I load it up before closing and I put in some winterizing tabs. Never had a problem with it. Pool is always crystal clear when I open.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Jul 2013
    63
    Thanks much. I appreciate the advice.
    Best--
    Al
