Results 1 to 11 of 11
Thread: Aqua Rite Chlorine Generators
    Aug 2013
    Damon, Texas
    8
    Is there a way to re-calibrate the Aqua Rite chlorine salt generators ?....just wondering.
    38,299
    Re: Aqua Rite Chlorine Generators
    Welcome to TFP!!!
    You mean the salt reading I assume? Not that I am aware of.
    What is your concern?
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    This is the only thing I know of. It's also discussed in this thread.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    38,299
    Yeah, that kind of fakes it out for awhile, but if it instantaneously is reading low, eventually the average will drop too.
    Aug 2013
    Damon, Texas
    8
    My chlorinator kept telling me that it was low on salt. The water tasted salty so I had the Turbo cell tested to make sure "it" was was not the problem.
    The Turbo cell passed, so I was advised to drain the pool 4 feet and add the necessary water to restart the chlorinator. So, I was just wondering if there was a way to re-calibrate the chlorinator like a fresh start. The pool is filling back up so I will see today if it starts over refreshed. Thanks alot !!
    38,299
    How old is the cell? When they start to go bad, they tend to start reading a salt level lower than reality. Have you independently tested the pool salt level?
    I have NO idea why they think that replace water to lower the salt level in the pool is going to make the SWG read a HIGHER salt level ... that is completely illogical ... but within lines of what pool stores are good at ... problem we do not understand, well time to replace some water.
    Aug 2013
    Damon, Texas
    8
    The cell is about is about 6 yrs old, but it was tested at the pool store. The water was tested there, and the reading I was told, was about 5700. My average readings are at 3200. That's why I had to lower the water, and refill the pool. Doing that as we speak, thanks !!
    38,299
    Well, likely you will end up with the cell not generating now because it is going to think the salt level is too low.
    General lifespan of a cell seems to be about 3-5 years.
    I am very curious to know what they do to test the cells.
    Aug 2013
    Damon, Texas
    8
    They attach the cell to another system of pvc piping and add salt water. The tester is turned on and runs for about a minute. At the end of the cycle, the message board states "passed". So I just assumed it was correct since they are in that type of business. Thanks for responding.
    38,299
    But what does "passed" mean? {I don't expect you to be able to answer, but you can see my thinking}
    That it turned on?
    That it actually generated something?
    That it actually read the correct salt level and generated?
    I am curious to see how this turns out, but pretty confident I know what will happen.
    Aug 2013
    Damon, Texas
    8
    Thank you guys for answering all my questions and I trust your replies. I'm sure now that the cell is bad and will be replacing it. Thank you again. This is a great forum.
