Results 1 to 10 of 10
Thread: New posts not updating
    Oct 2007
    Valrico, FL
    542
    It seems to me that when I click on the new posts link from the home page, It lists all posts since the change over. In other words the software is not keeping track of my last visit and showing just those post since my last visit.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: New posts not updating
    Click on "View active topics" it will work similar to the old "view new posts"
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    There is something in the programming that SeanB and the programmer worked on for a long time without success...
    after you have been 'gone' for 2 hours, the count resets.
    If you click that link, even with the wrong post count, the threads and posts are marked as read, so once you get in you will know what it really new.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    30,419
    Actually "log out" instead of closing the program and the new posts post will reset....to an extent.
    There are still some old posts there when I do that and I've yet to take the time to figure out what the software decides are "new" posts.....ain't it fun??
    sammm's Avatar
    North Richland Hills, TX
    257
    I'm having the same issue (I think). When I click 'View New Posts' I see stuff posted from last night and the most recent too. I've clicked 'Mark Forums Read' several times. Here's what's on the top of the window display - New Posts (since Sun Jun 15, 2008 10:07 pm)
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Quote Originally Posted by sammm
    But the actual posts and threads are marked read, correct? it is just the number on the portal page that is inconsistent, right?
    I don't ever log out of the forum, however that does seem to reset the number.
    sammm's Avatar
    257
    Quote Originally Posted by The Mermaid Queen
    Not sure. When I click 'View New Posts' I thought you should only see the posts that were made since last time you marked everything read. I logged off and back on and that seemed to reset things at that point.
    Riles_J's Avatar
    Nashville, TN
    218
    It doesn't seem like anyone else is having this problem, so it must be my setup, but I have to log on each time even though I check "log me on automatically" not a big deal. So I log on and then click right to View new posts and then it logs me off and says I'm not logged in. OK . . . so I do it all again and check to see I am logged in and then hit View new posts and it logs me off and says I'm not logged in. DOH! It seem as though I have been having to go to the index tab or somewhere else before hitting View new posts o for it to work. I'm puzzled with that one.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    30,419
    I'm having the same issue as j-riles. Just another one of those kinks that will get worked out in time.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    If you haven't already, try clearing your cookies.
