Results 1 to 8 of 8
Thread: Winter covers, pros and cons
    Planning ahead.
    I need a new winter cover this year. I have always used the "solid" type black tarp type covers, with water bags around the perimeter. Now that safety covers have come down in price, I'm contemplating them.
    What's your preferred type? Is there any advantage to keeping water out of your pool like the tarp type do, or do you prefer the constant drainage type of the mesh safety covers?
    Appreciate your thoughts and comments
    Mod Squad JohnT's Avatar
    SW Indiana
    9,166
    Re: Winter covers, pros and cons
    There are solid safety covers now, and also solid safety covers with mesh panels so you don't need to pump them off. I have a mesh safety cover, and I'm happy with it. No way anybody's going in the pool unless they want to.
    Cheap ones?
    My main concern with the mesh pools was the introduction of untreated water into sanitized and winterized water. I guess it's not a concern as long as you open the pool before the water hit's 60*?
    Mar 2007
    Coastalish 'down easter'
    4,160
    You're pretty much correct that closing late and opening early makes a HUGE difference in the amount of cleaning the pool will need with the old mesh covers. However, a couple of years ago we started installing what's called the 'sunblock' weave mesh covers and they honestly open about as clean as a solid cover. They weigh ~ 10- 15 lbs more than the older mesh covers of the same size but that's still about 1/2 of what a solid safety cover weighs BTW, all the solid safety covers I've dealt with have 'micro-mesh' panels in the center to allow water to drain while still keeping out all but the finest debris.
    Happy shopping for the cover - when it comes time to use it, juswt ask and I'll tewll you a few things that will make your life easier 8)
    Luv& Luk
    -Ted
    Thanks
    diloglm's Avatar
    Jun 2008
    Bel Air, MD
    8
    I am also debating which type of cover to buy...my solid cover lasted 2 years and seemed to always have excess, gross water on the top which I siphoned off! I am seriously considering the mesh cover.
    Waste, you had suggestions on how to use/install the mesh cover to make life easier. Could you please elaborate and share your thoughts. Thanks!
    Lisa
    My Pool: 24` round AG with surrounding deck, 13,500 gallons
    1 HP Hayward Pump, Sand Filter, BBB user and promoter :)
    Aug 2008
    MN
    19
    Yes, I would like to know also. I cannot for the life of me decide which type of cover to order. The mesh is sounding good but then I really need to order a leaf net also, right? Water temp today is 62, I would like to close it up soon being that I can't use it anyway.
    27' 17,000 gal. above ground.
    Pentair Meteor sand filter-22", uses 150lb of sand.
    Pentair Dynamo 1.5 hp pump
    new water cycler that uses prefilled pacs of chlorine
    ~BBB method
    Mar 2007
    4,160
    Hi guys and welcome!!
    I've recently added another link to my sig for closing time - in my post there I give tips for putting the cover on, but not how to install one. I'm gonna go and spend ~ 1 hour composing a basic installation 'How To' for safety covers which I will then link in this post as an edit (gotta do something on a rainy day when I can't be out closing pools )
    EDIT - I lied I started writing it and found myself less than 100% sure about what I was saying to do (it's been 10 months since I've installed one) so I want to wait until I do one this year, so I know my memory isn't wrong. (If any of you need help before I install one this year, just ask and I'll tell you from memory how to do it
    Luv& Luk
    -Ted
