Results 1 to 7 of 7
Thread: What is this ?
    Apr 2013
    NE Oklahoma
    53
    What is this ?
    That stringy brown stuff on the bottom? And what, if anything, should I do about it?
    M
    Newbie to pool ownership.
    5000 gallons
    Intex Krystal Clear sand filter pump 16" & saltwater system model CS20110
    AG Intex 16' x 48" Ultra Frame
    Leslie Chlorine FAS-DPD Service Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: What is this ?
    I don't know what it is, but I would clean it out and see if more returns. How do you swg plates look, is there any buildup on them?...this stuff could be from that.
    On a side note, we would recommend unplugging the electrical connector to the copper bars (in your picture) since you do not want to add copper to your water.
    Apr 2013
    NE Oklahoma
    53
    Re: What is this ?
    Okay. Tell me where the "plates" and I'll tell you what they look like.
    M
    5000 gallons
    Apr 2013
    NE Oklahoma
    53
    Re: What is this ?
    Unplug the copper thing? What's it for then? I just followed the set up instructions.
    Is the sorta flat thing connecting from the sand box to the outtake valve the 'plates'?
    M
    5000 gallons
    Apr 2013
    NE Oklahoma
    53
    Re: What is this ?
    Oh wait. The copper things stay there, just disconnect the plug that I would presume charges them? Is that what you mean?
    M
    5000 gallons
    38,301
    Re: What is this ?
    Quote Originally Posted by JustThe12OfUs
    Yes.
    Although some people have removed the bars completely.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: What is this ?
    Yes.
    It produces copper ions which act as an algaecide. Unfortunately, copper can stain pool surfaces and turn blond hair green. Good news is, proper levels of chlorine (in your case produced in the generator) is all you need.
    That looks like them. There should be no build up on the plates. Make sure you look between them too, you may have to remove them from the container to do so. If you are seeing build-up, that is a chemistry issue.
