Thread: Vacuum to waste
    Jun 2008
    Pittsburgh
    4
    Vacuum to waste
    Does anyone know of a way I can use my sta-rite prc75 cartridge to vacuum to waste.
    Thanks Wilssm
    Re: Vacuum to waste
    There is a way, but I don't really recommend it. You can remove the cartridge and leave the filter case open. Most of the water will come out of the filter, probably in a large spray, and only a little will go back into the pool. You might need to protect the pump from getting too wet. This can make a huge mess, which you have little control over, but it would have the desired effect.
    Jul 2007
    Waterford Michigan
    36
    Re: Vacuum to waste
    Is there a second plug in the bottom of the filter housing? If so change the plug out to a nipple and valve, that should give you the abilety to pump to waste.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
