Thread: Filter problem
    New Jersey
    12
    Filter problem
    Hello all, I don't know if this a first for this forum but it is for me. After I just completed changing a defective seal in my pump and was preparing to reinstall it, I found a small pinhole leak in my filter. I panicked of course and called my local pool store. They suggested a epoxy patch but warned it probably wouldn't last. I applied the patch yesterday afternoon and let it dry overnight. I was all set to reattach the pump and refill the filter today but the weather did not want to cooperate. So, while I'm waiting for the storm to pass I figured I'd post this and send some pics.
    21k gal, Inground vinyl, 1 1/2 HP Emerson pump, Micromatic 26" filter, Aquacal heat pump w/solar cover, Manta automatic pool cleaner
    22,548
    Re: Filter problem
    How old is that filter?
    38,275
    Re: Filter problem
    Generally patching a pressure vessel is not a good idea. And if you were going to try, it should likely be done on the inside.
    It looks pretty new, any chance it is still under warranty?
    New Jersey
    12
    Re: Filter problem
    It's 10 years old, I doubt that it's still under warranty but I'll check. As for patching from the inside, the hole is near the bottom. I don't think I could reach down that far through the opening in the top.
