Results 1 to 9 of 9
Thread: recurring algae problem
    My pool, located in San Diego, was resurfaced last year with a medium grey plaster. After start up the pool company set the CYA to 60 PPM. Not knowing better, I used tablets for a few months and my CYA rose 80 PPM. On 2 separate occasions this summer algae growth has forced me to shock the pool following the "pool school" instructions using bleach and muriatic acid. However, both times the algae returned within a few weeks. Being at the upper end of the CYA spectrum, I suspected that this might be impeding my efforts. 10 days ago I completed the shock process and passed the overnight test. The next day I treated with polyquat 60 for 24 hrs. I then backwashed the filter and drained 25% of the water to get my CYA down to 60 PPM. Since then I've checked my levels daily and kept my FC between 5 and 9 PPM. PH has been between 7.4 and 7.8. All testing is done with the recommended Taylor 2006 kit. Now 10 days later I see algae forming on the vertical edges of the stairs in the shallow end. This is usually where it starts and then it spreads around the entire surface of the pool. It appears to be green, but the true color could be skewed by the grey plaster. Oddly it only grows on plaster, never the vacuum or the vacuum hose which remain in the pool 24/7. The water itself remains clear.
    I'm at a loss as to how algae can be taking root in a pool with ideal levels of free chlorine and the following parameters.
    DE filter runs 9 hrs / day
    Alk = 190
    FC = 5-9
    CC = 0
    CYA = 60
    pH = 7.4 - 7.8
    Anyone have any ideas as to what the problem might be? I am guilty of not brushing my pool. In fact in the past 10 days I did not run the vacuum or brush the sides. Could this be enough to seed the problem?
    30,419
    Re: recurring algae problem
    parkerman,
    Welcome to the forum. Algae establishes in pools that have inadequate chlorine....period. Rather than dwell on how your algae got started, I would get rid of it. You get rid of it by SLAMming the pool per the article in Pool School. Brush, vacuum and run your pump 24/7 during the process.
    While your test results look fine, just keep in mind that the algae is in your pool because your chlorine has been inadequate....no other reason.
    Follow the SLAM process correctly and the algae will go away. It will only reoccur if you allow the chlorine to fall too low and/or fail to practice good maintenance technique like vacuuming, brushing, etc.
    Mark92677,
    Controlling phosphates are a completely unnecessary part of pool water management. Thousands of us here on the forum never test for them and never will. Google "phosphates" here on the forum and read more about the logic behind ignoring them.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum, parkerman
    +1, what duraleigh said, ignore phosphates.
    If you passed all three tests to be done with the SLAM process (see red lines in my sig), then you may have Mustard Algae.
    It is a persistent type of algae that goes away at normal shock levels only to reappear when levels drop back to maintenance levels.
    You can read about mustard algae here and see if you think your pool fits the definition:
    pool-school/mustard_algae
    Very possible. Also, how is the circulation in your pool? If you have any 'dead' areas where the circulation is poor, this could also contribute. Regardless of the cause, the SLAM process is the beginning of the cure.
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Also check behind light fixtures and around ladders (if you have one). Here's an example of what was behind a light fixture of a pool that had clear water but was suffering from persistently high chlorine demand: http://www.troublefreepool.com/think...ue-t65957.html.
    Thanks for the feedback everyone. I've been reluctant to believe that I'm dealing with mustard algae, because it looks green and is not patchy. However, there is no denying it's fits the description of recurring post SLAM, once maintenance levels of chlorine are restored. Again the grey plaster might be skewing the true color of the algae. I had thought about treating the pool as if it were mustard algae, but my CYA was so high, it would've taken a ton of bleach and I thought the use of polyquat might remedy the situation as well. Now that I'm down to a CYA of 60 I may have to do the mustard algae super SLAM.
    As for the light, I will remove that over the weekend. I see just one screw in the outer edge. Is that all it takes? Just back that out and pop the light out?
    As for dead zones and circulation. I have 2 returns and they're almost right next to each other and pushing water the same direction. Which seems less than ideal. In addition I have a variable speed pump that I run at low energy saving RPM for 9 hrs. Should I consider to up the RPM for some of that time to get more vigorous circulation?
    Donldson's Avatar
    NW Ohio
    2,894
    Keep in mind that the mustard algae SLAM is the same during the SLAM portion, it is after the SLAM is completed that you raise the FC level to mustard algae levels for 24 hours.
    Make sure the SLAM is seen clear through, the 3 criteria passed as well as zero visible algae and checking everywhere algae might be able to hide. After you pass everything if you want to raise your FC to mustard levels just to be sure then go for it. The more thorough you are in the SLAM the more likely this issue will finally clear up for you.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Moved phosphate discussion here: post572903.html#p572903
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by parkerman
    Yep, turn off power first. Did you remove the light? Did you find anything?
    Yes, that sounds like a plan. But, nothing replaces brushing including all the nooks and crannies.
    Got an update for us?
    On the light--flip the breaker off first.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
