Thread: Advice on repairing heat pump
    Apr 2012
    Mason, Ohio
    119
    Last week I noticed that my heat pump wasn't working right. I called Raypak - the rep walked me through a few things and determined that the problem was either the capacitor or the contactor. His advice was to replace both. The heat pump is two years old. The parts were under warranty, but the labor was not. So I'm hoping that these are things that I can replace myself. I received both parts but no instructions. It looks like both should be plug 'n play, but thought I'd check here for any advice on what to make sure I do (triple check that the breaker is off) and what to make sure I don't do.
    Here are the parts:
    Capacitor
    Contactor
    Thanks!
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    22,553
    Re: Advice on repairing heat pump
    Take pictures of the installed parts and then unhook the wires one at a time and hook it onto the new part. Then unmount the old part and mount the new part.
    CAUTION: The capacitor can hold a charge. Short across the terminals with screwdriver (or other insulated handled device) to make sure it's discharged. Be aware that you may get a spark when doing that. It should self discharge if the power has been off a while, but you never know.
    Apr 2012
    Mason, Ohio
    119
    Good advice - thanks!
