Thread: Test results ...
    Jul 2013
    Chicago IL
    83
    Test results ...
    5300 gal Above ground /Clear water, anything needed here::
    FC 8.5
    CC 0.5
    PH 7.8
    TA 150
    CYA 35
    Been using -Liquid Chlor/Borax as needed
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Test results ...
    Looks pretty good...your FC is a little higher than it needs to be, but won't harm anything. I would lower your ph down to 7.2 and repeat that everytime it gets back up to 7.8...these Muriatic Acid additions will also slowly lower your TA which eventually will reduce how fast your ph is going up.
    How much FC are you losing each day?
    Jul 2013
    Chicago IL
    83
    I just comming off a slam ... I was losing about 3ppm a day , even with the pool solar covered. So i brought the FC up to 15 a few days ago. Its comming down gradually being 95deg here in chicago. I was a little concerned about the TA being 150. But ph hasnt been a problem.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sounds like you are in good shape then.
    Jul 2013
    Chicago IL
    83
    Thanks again !
