Thread: algae?
    May 2013
    CT
    17
    algae?
    I can't figure out what keep reappearing on the bottom of my pool. I think it is algea, brownish in color. The puzzling thing is my water is otherwise clear. The FC level runs from 3-5 depending on how recently I have added 12% bleach. PH is at 7.8 AK is at 11 and CYA is at 4.5
    I vacuum and it is back the next day albeit slightly.
    Suggestions on how to treat and what in fact I have?
    Thanks!
    15600 AG
    Filter Cartridge
    Waterway HI-FLO 48 2 Speed
    HI-250 GPM,LOW-144 GPM
    BBB,Leslie DPD Tester
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: algae?
    Where did you get your test results? CYA=4.5 is not correct. You cannot measure a CYA that low.
    -- Guy --
    38,251
    Re: algae?
    What test kit are you using? Your TA and CYA numbers do not make sense.
    What does it feel like if you run it between your fingers?
    Could be a low level algae bloom that is barely being held in check and leaving the water clear. An OCLT should be able to confirm if you have algae and need to SLAM the pool.
    May 2013
    CT
    17
    Re: algae?
    thank you. I forgot to move the decimals on the AK it should be 110 and CYA should be 45. Long day.
    15600 AG
    Filter Cartridge
    30,403
    Re: algae?
    If you see visible debris on the pool floor each day and it is brushing up into a cloud, it is surely dead algae.....regardless if your water is clear or not.
    To get rid of it, you will have to SLAM the pool according to the article in Pool School.
    I suggest reading "The ABC's of Pool Water Chemistry" up in Pool School and then read "SLAM - Shock Level And Maintain".
    If you continue more of what you are currently doing, you will continue getting the same results.
